Yamaha CS80 group photo
Yamaha CS80
Archive for yamahacs80.
Sources of key contacts for Yamaha CS-80
2013-02-16 by Mitchell Manger
Could anyone recommend some Yamaha instruments that are good sources of replacement key contacts for the CS-80?  I heard from a tech that a CP-30 was a good source because had identical key contacts, so I bought one and tried to use it for that purpose.  However, the tech turned out to be incorrect, as the CS-80 uses a side-by-side pair of contacts per key, while the CP-30 only has one contact per key, and the contacts are immovably fixed in the plastic mold.
Any help would be greatly appreciated.
Thank you,
Mitchell Manger
Re: [yamahacs80] Sources of key contacts for Yamaha CS-80
2013-02-16 by David Rogoff
On Feb 16, 2013, at 12:01 AM, Mitchell Manger <mitchell.manger@...> wrote:
> Hi,
Mitchell,
let us know if you find something, but I'd bet that none of the CS-80's keybed parts were used on any other synth :(
David (off to make a CS-80 house call this afternoon …)
