Yamaha CS80 group photo
Yamaha CS80
Archive for yamahacs80.
Sub Oscillator Problem
2012-11-15 by Tony
Hello to all
My CS 80 Sub Oscillator works fine with aftertouch but not direct.
And one of the preset selector lamps stopped working (bass) what
kind of replacement should i look for ?
The other problem i have: my CS 60 is just the opposite the Sub Oscillator works fine direct but not with aftertouch.
any clues on these matters ?
Thanks in Advance
Is there maybe somebody over here who has the complete and correct dimensions for the CS 80 stand ?
Re: Sub Oscillator Problem
2012-11-20 by Tony
Anyone ?
--- In yamahacs80@yahoogroups.com, "Tony" <tonymonta2002@...> wrote:
> Hello to all
> Thanks in Advance
Re: [yamahacs80] Sub Oscillator Problem
2012-11-20 by David Rogoff
On Nov 15, 2012, at 7:47 AM, Tony <tonymonta2002@...> wrote:
> Hello to all
There's someone in the group who researched this and found a replacement and I think sells them. Sorry - forgot the name right now but you can search old messages for bulb.
> The other problem i have: my CS 60 is just the opposite the Sub Oscillator works fine direct but not with aftertouch. any clues on these matters ?
I traced this out and posted a picture that shows the schematic and board layout for the sub output here: http://groups.yahoo.com/group/yamahacs80/photos/album/2026019202/pic/1379138874/view?picmode=original&mode=tn&order=ordinal&start=1&dir=asc
It looks very simple. There are 2 white wires coming off the sub board from the sub output. One goes to the TRG5 board for the sub aftertouch and the other goes straight up to the direct knobs on the front panel. Looks like a bad connection or broken wire - at least for the CS80 problem. Should be very easy to spot and fix.
I can do this in the next couple of days.
David
2012-11-21 by Mike
Ive got bulbs if you need them.
> > Hello to all
> David
2012-11-21 by Tony
Thanks a lot David
I fixed the CS 60 today, i replaced IC 4 and 5 (SUB) and that solved the problem.
I also "fixed" my CS 80, i didn't mention mine has a internal Kenton midikit.
The problem was a toggle switch in the wrong position, so the levers didn't
work direct, not very bright of me i know :)
I was checking the white cables you mentioned, they where all in place, then i realized my mistake :)
If you have time for the dimensions that would be more than fantastic, thanks again for your help.
> > Hello to all
> David
2012-11-21 by Tony
Hi
Are you the person who offers them on ebay as set ?
because i'm thinking of replacing them all.
Kind Regards
> --- In yamahacs80@yahoogroups.com, David Rogoff <david@> wrote:
> > On Nov 15, 2012, at 7:47 AM, Tony <tonymonta2002@> wrote:
> > > Hello to all
> > David
2012-11-22 by Mike
Yup. I'm the guy. I'll post a set for sale on e-bay if you want. If you're comfortable, you could just pay me via paypal and I'll try and help you with shipping.
U.S.A. shipping is $6.50. Shipping to Europe can range from $10 to $30.
-Mike
> Hi
> Kind Regards
> > > > Hello to all
> > > David
2012-12-12 by Mike
I can help you with the panel bulbs. It took me years to find replacements, so I made a group buy and have been supplying bulbs to CS80 enthusiasts ever since. I have some replacement kits left if you are interested.
Regarding your sub oscillator, I can fix it for you if you live in Chicago. Or, If you know a little bit about electronics and can follow my instructions, perhaps I could walk you through the solutions.
-Mike
312-363-7286
> Anyone ?
> --- In yamahacs80@yahoogroups.com, "Tony" <tonymonta2002@> wrote:
> > Hello to all
> > Thanks in Advance
2017-09-19 by joaopaulosilva12@...
Hi. Do you still have any of those bulbs for sale?
-Mike
312-363-7286
> Anyone ?
> > Hello to all
> > Thanks in Advance
