Yamaha CS80 group photo
Yamaha CS80
Index last updated: 2026-03-31 01:50 UTC
R: Re: [POSSIBLE SPAM] [yamahacs80] CS60 weirdness
2012-06-03 by faxiomas@virgilio.it
Hi Laurie, thx for your reply; unfortunately the Sustain seems not to affect the pitch; I suspect is more a KAS matter, anyway I'll test Sustain more thoroughly.
M
----Messaggio originale----
Da: laurie@...
Data: 3-giu-2012 2.10
A: <yamahacs80@yahoogroups.com>
Ogg: Re: [POSSIBLE SPAM] [yamahacs80] CS60 weirdness
Da: laurie@...
No idea Max.... this definatly isnt the pitch deal on a CS80 ..... does this problem effect work the same in both susI and SusII ???
To: Yamahacs80 <yamahacs80@yahoogroups.com>
Date: 06/02/12 18:05
Subject: [POSSIBLE SPAM] [yamahacs80] CS60 weirdness
Hi all
I've sent a message some days ago with no reply.
I'm calibrating a 60 and discovered some weird things:
-if the machine's VCOs are set on 1OCT UP and I play the upper C6 note, then I bend up one octave while pressing the key, the pitch gets stuck and so goes with all the following voices
-with the SubOscillator modulating through rising saw I can clearly see a strange thing on the oscilloscope: the CV signal coming out of the Vca is clearly warped at +0.5V, so there is a distortion placed only at this amplitude.
Can anybody tell me anything about these problems or where and how to look?
M
