SY-1 problem
2012-05-01 by papinje
Archive for yamahacs80.
2012-05-01 by Stephen Parsick
> Datum: Tue, 01 May 2012 08:30:52 -0000--
> Von: "papinje" <fernandozarone@...>
> An: yamahacs80@yahoogroups.com
> Betreff: [yamahacs80] SY-1 problem
> Hello.
> the touch control in a SY 1 does not work. With TC sensitivity
> potentiometer at its maximum, the touch controlled effects go to the maximum, but
> are not modified by the key pressure.
> Inside the machine, the lamp is lit, the "shield" moves well. What to
> check? How can I test the light variable resistor?
> Every help is appreciated…
> Fernando
2012-05-01 by Quazimodo
--- In yamahacs80@yahoogroups.com, "papinje" <fernandozarone@...> wrote:
> Hello.
> the touch control in a SY 1 does not work. With TC sensitivity potentiometer at its maximum, the touch controlled effects go to the maximum, but are not modified by the key pressure.
> Inside the machine, the lamp is lit, the "shield" moves well. What to check? How can I test the light variable resistor?
> Fernando
2012-05-01 by Fernando Zarone
> With a meter on ohms. I would disconnect the LDR from the circuit whilst checking..![Non-text portions of this message have been removed]
> Cannot say what the spec should be but if there is no touch sense - there will be no meter movement...and there should be "some".
> Cheers,
> TOM
> > Hello.
> > Every help is appreciated�
> > Fernando
--- In yamahacs80@yahoogroups.com, Fernando Zarone <fernandozarone@...> wrote:
> Thanks;
> I have done it, Tom,
> after being disconnected, the light sensitive resistor varies from 195 Ohm (no pressure) to 175 Ohm (max pressure)
> Is it correct in your valuable opinion?
> F
> > Cheers,
> > TOM
> > --- In yamahacs80@yahoogroups.com, "papinje" <fernandozarone@> wrote:
> > > Hello.
> > > Fernando
2012-05-02 by synthparts
--- In yamahacs80@yahoogroups.com, "Quazimodo" <noddyspuncture@...> wrote:
> Personally Fernando, I think that your LDR is faulty - going off your findings. That is just a 20 ohm swing.
> Let me get round to it and I'll try and check the LDR in my CSY-1 that I am converting here. It should be the same. I do know LDR's are many and varied, so you will need the right one, but they are readily available.
> You're in no particular rush for this?
> Cheers,
> TOM
> --- In yamahacs80@yahoogroups.com, Fernando Zarone <fernandozarone@> wrote:
> > Thanks;
> > F
> > > Cheers,
> > > TOM
> > > > Hello.
> > > > Fernando
2012-07-19 by Fernando Zarone
