Bottom key re-trigger and sustain [CS-80]
2012-03-27 by effegee
Please let me know if this has already been addressed or if it's a known issue.
In sustain mode I, when I play a note with a long release (or with the sustain slider set high with the sustain pedal activated), release the note, and then I play a lower note, the higher note is retriggered. It doesn't happen when I'm still holding the higher note. It also doesn't happen when I play a note higher than the first note played. If I do the same thing, but instead play a chord, the chord is retriggered when I play a lower note.
Also, the "re-triggered" notes are unaffected by filter or envelope, i.e., if the filter cutoff is low on the sustaining notes, the re-triggered notes always have a sharp attack and wide-open filter.
What's going on here? Is there a fix?
