Yamaha CS80 group photo
Yamaha CS80
Index last updated: 2026-04-03 01:46 UTC
CS-80 key contact blade springs
2012-03-02 by lt_picard_voyager
I have some bended key contacts in my CS-80.
I could try to bend the springs back in the original shape. It will be difficult because it is very tiny and has to be done with surgeon precision and I do not want to do it anymore harm. Before I do that I would like to know if somebody has a spare PCB `Yamaha LC 21 571 JCI-AK H' completely with the springs on it, so I can use it as an easy drop in replacement?
You can find pictures of the print I am searching on my flickr account : http://www.flickr.com/photos/41267611@N06/sets/72157629112502438/
Anybody has other tips or advice on tools or techniques to adjust the springs back in original shape?
Already I purchased a 2nd hand Yamaha CP-30 piano. This piano has the same keyboard in it. But the prints with the key contact springs are not identical as in the CS-80. Although the black plastic key spring holders and the contact springs it selves are the same.
This week I phoned with Kent Spong. Kent told me he tried once do use contact springs from a Yamaha CP-20. He desoldered the springs. But the springs are clicked in the black plastic holder and not removable. Removing the springs from the holder would be destructive. So I do not suspect that will be a success to try.
Any advice, I would be grateful,
Greetings,
Lt
Re: [yamahacs80] CS-80 key contact blade springs
2012-03-02 by jkjelec@comcast.net
I've had good luck bending CS80 keyboard contacts back into shape, even when they were as bent-up as the ones you showed.  They must be made of good quality spring steel.  I just held one end  in place using needle-nose pliers. and then bent the other end by hand.  I had to overbend them a little, and then they would end up approximately back where they belong.  Of course there's always a chance one could break while being bent.
jkjelec
To: yamahacs80@yahoogroups.com
Sent: Friday, March 2, 2012 3:52:37 AM
Subject: [yamahacs80] CS-80 key contact blade springs
Greetings,
Lt
Yahoo! Groups Links
Re: [POSSIBLE SPAM] Re: [yamahacs80] CS-80 key contact blade springs
2012-03-02 by Laurie Curry
Just remember... they do snap with manipulation and time.... I had to solder one of the hook end springs back together ...
Date: 03/02/2012 08:25
Subject: [POSSIBLE SPAM] Re: [yamahacs80] CS-80 key contact blade springs
jkjelec
Greetings,
Lt
Yahoo! Groups Links
Re: CS-80 key contact blade springs
2012-03-07 by lt_picard_voyager
Thank you for the advice.
I succeeded in bending them back. I used two needles.
I bended the end of the needles 90� degrees with a plier.
Manipulating the bended needles as a tool I was able to bend them back.
Greetings,
Lt
Re: [yamahacs80] Re: CS-80 key contact blade springs
2012-03-08 by Tommy Priakos
Dear L_P_V,
Any chance you took pictures?
After you bent them with the pliers, I assume you used the pliers to grip the needles?
TP
On Mar 7, 2012, at 2:31 PM, "lt_picard_voyager" <blueridge@...> wrote:
> Hi,
> I bended the end of the needles 90° degrees with a plier.
> Greetings,
> Lt
2012-03-08 by Quazimodo
The question is, why did they bend in the first place...? Is this common...?
Cheers,
TOM
--- In yamahacs80@yahoogroups.com, Tommy Priakos <tpriakos@...> wrote:
> Dear L_P_V,
> Thanks,
> TP
> > Hi,
> > Greetings,
> > Lt
