Excellent news! Keep the group informed - lots of potential customers
here!
Of course, this all begs the question of a complete M-Card replacement...
David
p.s. - for the M-Card replacement, I'd like additionally selectable
Oberheim SEM and Moog Ladder (904A AND Minimoog while I'm asking...)
filters. And don't tell me you haven't thought of (and possibly
prototyped) this :) Also much nicer trim pots for tuning and
calibration - assuming it doesn't have built-in auto-cal!
> The Old Crow <mailto:oldcrow@...>
> November 14, 2011 1:26 PM
> Hi David,
> The VCO153 and GX1BPF will be assembled 5U-format modules I will be
> offering myself, though my company. The IG153 (retrofit board for
> IG00153 chip) and JH151 (retrofit for IG00151) are likewise
> pre-assembled SMD boards for use in replacing those custom ICs, and will
> be offered probably around March 2012. I will also have a small board
> for replacing CA3080 OTAs with a small discrete OTA cell and a board for
> offering a dual matched NPN (or PNP) pairs with an included 1K 3300ppm
> thermal-contact resistor, both boards having a DIL-8 pinout.
> The modules can use a Moog-style front panel if so desired, though
> you would need to get the panels made/lettered--Arrick sells the
> blanks. At some point I might offer a frac-rack version--we'll see.
> Someone asked about replacing the EG chips. This is somewhat more
> complicated in that it is hard to get that many parts into a retrofit
> board that would fit reasonably into an IG00152/159 socket location.
> But, I have a solution that involves using a microcontroller to do the
> envelopes with high enough resolution one cannot tell the functions are
> computed in the discrete time domain instead of the continuous time
> domain.
> We'll see.
> Regards,
> Scott Rider
> http://www.cs80.com/
> David Rogoff <mailto:david@...>
> November 14, 2011 7:56 AM
> Hi Scott.
> Good to hear from you. Look forward to your new modules! Will they
> also be through Paul / MOTM?
> David
> November 13, 2011 7:50 PM
> Hey folks,
> Yes I have been very busy, but I am still here. Overhauling a CS-80
> for someone right now, in fact.
> I have tested my IG00153 board, it works fine. I am trying to get
> several chip-level and modular synthesizer products ready to ship by
> Jan. 1, including the 151, 153 and two 5U modules (GX1 bandpass and
> VCO153).
> Scott Rider
> organissimo <mailto:b3groover@...>
> November 13, 2011 12:19 PM
> Hello folks!
> I'm new to the group. I just purchased a Yamaha CS50 that only has one
> voice card fully functioning. Thankfully I got the synth very cheap.
> I've traced the issues down to two EGs and a couple VCAs. But as
> everyone knows, those proprietary Yamaha chips are becoming more and
> more scarce. This is a problem that will only be exacerbated as time
> marches on.
> I've found some old posts on this group from Scott Rider (Old Crow)
> concerning re-creating some of these chips. I've emailed Scott but
> have yet to hear back. It seems he hasn't posted in a few years as
> well. I hope he is ok.
> Has anyone else looked into re-creating these chips? I'm not an
> electronics engineer by any stretch of the imagination. But it seems
> like it would be possible, using modern components like the THAT 2181
> VCA, to create a viable substitute for chips like the IG00151 VCA.
> Thoughts?
> ----Jim
