CS-80 keybed aftertouch resistors
2011-05-19 by Max Fazio
Index last updated: 2026-03-31 14:10 UTC
2011-05-19 by Laurie Curry
2011-05-19 by Andrew Kirkby
On 20/05/2011, at 8:40 AM, Max Fazio wrote:
> Hi all
> With your kind help , I need to know something about the variable
> resistors put in the keybed and bound to the aftertouch: according
> to the big diagram there are 3 of them for each key: in case I'm
> happening to service an 80 what should be the replacement for them?
> Ohmic value/tolerance?
> Thanks for your help!
> M
Andrew Kirkby
(e) kirkbyte@...
(m) 0416 000 070
2011-05-20 by Max Fazio
To: yamahacs80@yahoogroups.com
Sent: Friday, May 20, 2011 1:41 AM
Subject: Re: [yamahacs80] CS-80 keybed aftertouch resistors
are they really variable??? I thought they were fixed resistors Max...and the carbonised rubber bridge piece squished down to bring them all into the circuit.
Date: 05/19/2011 17:40
Subject: [yamahacs80] CS-80 keybed aftertouch resistors
Hi all
With your kind help , I need to know something about the variable resistors put in the keybed and bound to the aftertouch: according to the big diagram there are 3 of them for each key: in case I'm happening to service an 80 what should be the replacement for them? Ohmic value/tolerance?
M
To: <yamahacs80@yahoogroups.com>
Sent: Friday, May 20, 2011 1:45 AM
> Hi Max,
> Are you talking about the FSR (force sensing resistor)?
> Those are the key and aftertouch sensor...
> Andrew
>> Hi all
>> M
> Andrew Kirkby
> (e) kirkbyte@...
> (m) 0416 000 070
2011-05-20 by Andrew Kirkby
On 20/05/2011, at 10:03 AM, Max Fazio wrote:
> Hi Andy
> Yes, the FSR , I was referring to the aftertouch sensors
> anyway...just I
> find it odd that yamaha is reporting three resistor symbols for each
> key on
> the diagram, where the aftertouch contacts are drawn...what could
> that mean?
> M
> From: "Andrew Kirkby" <kirkbyte@...>
> > Hi Max,
> > Andrew
> >> Hi all
> >> M
> > Andrew Kirkby
> > (e) kirkbyte@...
> > (m) 0416 000 070
> > Yahoo! Groups Links
Andrew Kirkby
(e) kirkbyte@...
(m) 0416 000 070
Sent: Friday, May 20, 2011 2:18 AM
> Max,
> Unless they are not functioning properly i wouldn't try and replace
> them. In any case, i have not come across a suitable part in two years
> of casual searching. Sensitronics in the USA might be able to make
> them - but they would be expensive and a substantial custom order
> would be required.
> Andrew
>> Hi Andy
>> anyway...just I
>> key on
>> that mean?
>> M
>> > Hi Max,
>> > Andrew
>> >> Hi all
>> >> M
>> > Andrew Kirkby
>> > (e) kirkbyte@...
>> > (m) 0416 000 070
>> > Yahoo! Groups Links
> Andrew Kirkby
> (e) kirkbyte@...
> (m) 0416 000 070
