Yamaha CS80 group photo
Yamaha CS80
Archive for yamahacs80.
CS80 leg mouting hardware
2008-01-22 by Rick
would someone with the original leg hardware mind pulling one of the
handscrews out and posting info about shaft length and thread size to
the group.. if I can get this info I will hunt down a sub and post a
link as well. I'd like to get some handscrews to keep my synth together
there should be 4 of these to attach the stand.. and one to keep the
stand together in the middle.
thanks!
-rick
Re: [yamahacs80] CS80 leg mouting hardware
2008-01-22 by rj krohn
rick, i can pull one out, but i dont know how i would accurately describe the thread size. its definitely not "machine screw thread" type, and i remember the shaft to be around 2" long. tell me know i can accurately measure it and i can help you out....
Rick <echo7even@...> wrote: would someone with the original leg hardware mind pulling one of the
thanks!
-rick
Never miss a thing. Make Yahoo your homepage.
Re: CS80 leg mouting hardware
2008-01-22 by Rick
hm..some people are really good at telling threads by looking at
them.. My friend Richard is great with that sort of thing.. me.. not
so much.. i think japan is on the metric system
not sure if this would help: http://www.skgrimes.com/adapter/index2.htm
together
> thanks!
> -rick
2008-01-22 by Rick
in an older post David Rogoff claims they are metric #8 bolts...hmm
-r
> > Rick <echo7even@> wrote: would
> together
> > thanks!
> > -rick
2008-01-22 by Rick
JL measured them for me.. here is the info for the archives
8 X 1.25 thread, 25 mm long
-rick
> -r
size to
post a
> > together
keep the
> > > thanks!
> > > -rick
Re: CS80 leg mounting hardware
2008-01-22 by David Rogoff
I also bought matching wingnuts and screwed and epoxied them onto the
bolts to give them a handle that can be screwed in by hand.
> -rick
> > -r
> size to
> post a
> > > together
> keep the
a joyful discovery on a non-working voice card!
while finally getting a chance to work on some voice card issues today, i made a very exciting discovery. i traced voltages on an IG00153 chip i was about to replace, and discovered that it was not being fed all the proper voltages, and traced the problem to i believe a bridge rectifier or transistor! i think this now means i have a failed $.30 part, not a failed $50+ part! i am quickly approaching a 100% CS-80! 2 voice cards left to go......
and on the subject of chips, if anyone needs an IG00157 chip, i can direct them to where one is available. drop me a line if you need one.
