Working on live boards?
2008-01-09 by JH.
Index last updated: 2026-03-31 22:34 UTC
2008-01-09 by JH.
2008-01-09 by jkjelec@comcast.net
> When I want to measure on an individual board (like the PRA board) - can I[Non-text portions of this message have been removed]
> do this outside the card cage?
> I know the mounting screws carry +15V and GND, but there's also cables
> running to the board for +15V and GND, so it should be possible to remove
> them, turn the CS-80's power on, and measure on the boards- right ?
> Please confirm, or stop me from making anything stupid ...
> JH.
2008-01-09 by JH.
> It is fine to work on the boards live, removed from the card cage. I doThank you Kyle! Now that you say it, I think I have done it on the CS-50,
> it all the time and never had a problem; as you surmised, the power >
> supplies also are routed to the boards through wires.
>JH it is awesome that you finally have an '80! I and many others areThanks for your nice words. Yes, I love to modiy and also to share the mods.
>looking forward to your insights as you delve inside it.
> JH.
2008-01-09 by rj krohn
> it all the time and never had a problem; as you surmised, the power >Thank you Kyle! Now that you say it, I think I have done it on the CS-50,
> When I want to measure on an individual board (like the PRA board) - can I---------------------------------
> JH.
2008-01-09 by The OldCrow
> JH.
2008-01-09 by Rick
--- In yamahacs80@yahoogroups.com, The OldCrow <oldcrow@...> wrote:
> I have an old wooden drafting board i set on top of the keyboard
frame
> that I work on boards with without fear of shorting against live or
> grounded rails. Each card will operate removed from its cage position.
> Crow
- can I
cables
remove
> > JH.
2008-01-09 by JH.
> JL and I were discussing the reason why Yamaha decided to run theOr getting a very low GND impedance from board to board.
> supply line to the cages.. anyone have a clue why they did this other
> then perhaps trying to battle ground loops?
