To: <yamahacs80@yahoogroups.com>
Sent: Tuesday, November 06, 2007 11:01 PM
Subject: [yamahacs80] Re: CS80 PSU mod-anyone ever done this?
fwiw, i went down the route of modding the cs80 with some external fx built
into the unit... (changing the Cs80 chorus for a dc-2 circuit and changing
the tremolo circuit for a PH-3 circuit)
it was a BAD idea, DO NOT mod classic synths, leave them as they are...
Fortunately i only modified (drilled for extra pots) the modulation panel, i
managed to source another modulation panel and am changing it back
completely to a standard unit...
My own fault... but my answer is DONT modify the Cs80, work with what you
have...
> ahhhh, thanks for the thought, JH. that makes sense. i would rather not
> pioneer a mod on a synth that is as rare as this, but it seems to be very
> sensible and almost simple. im envisioning nothing more than a 3-5 ft
> umbilical-style cord with a multi-pin connector that screws in(my trident
> console has one that would work perfectly), mounted in the base of the
> chassis, right where the PSU is now. then you could set the psu on the
> floor within a few feet of the base of the chassis(of course mounted in
> its own chassis!).
> i wonder, how much impedance could be lost between 8" and 5'? (i guess
> thats a question for my multimeter.)
> "JH." <jhaible@...> wrote: I've
> never done this (in fact, my CS-80 isn't even in my home yet), but I'll
> offer one thought nevertheless:
> The GND impedance may be a problem.
> Linear VCOs are very sensitive to small offset voltages in the low
> frequency
> range, so a voltage drop across the GND connection may be a problem. I
> have
> that theory, which isn't any more than a gut feeling right now, and may
> be
> totally wrong, that the slight coupling via voltage drop *inside* the
> CS-80
> may play a role in it's increadible lush-ness - then a longer GND path
> might
> turn the feature into a problem.
> But then again there's a servo sensing for the PSU regulation if memory
> serves - that would *allow* a rmote PSU (with sense and power wires both
> going thru the umbilical cord).
> JH.
> From: "rj krohn" <r_j_d_2.phila@...>
> Sent: Tuesday, November 06, 2007 7:31 PM
> Subject: [yamahacs80] CS80 PSU mod-anyone ever done this?
> hi folks, i wanted to ask why a particular mod has never been discussed,
> or
> done, to my knowledge on CS80's. hoping for some practical answers, to
> see
> if i consider should setting out on this.
> it seems like it would be relatively easy to detach the PSU from the
> CS80,
> and make it an external unit. im assuming that most(if not all) of the
> reknowned pitch instability/temperature issues were due to the massive
> PSU/input transformer. after seeing this firsthand, i see there are just
> two
> harnesses and a ground wire that connect to the rest of the synth. it
> seems
> like it would be pretty easy to take the PSU out, install 1 or 2
> connectors
> to adapt the harnesses to, and build an external box for the PSU. there
> cant
> be more than 16-18 total harness pins for the rails of the PSU. by now,
> im
> sure every cs80 in existence is a studio unit, and this wouldnt be too
> inconvenient, and could potentially help the stability. of course, the
> connector would have to be a screw-in type that could be well secured to
> the
> chassis.
> is there a reason this hasnt been done, or has this been covered already,
> and a terrible idea for some reason? thanks guys!
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
> Do You Yahoo!?
Rob Belcher
www.myspace.com/duplx
Yahoo! Groups Links
