Yamaha CS80 group photo
Yamaha CS80
Index last updated: 2026-04-03 01:46 UTC
Keyboard stand for CS-80
2007-09-18 by dark_november2000
I've been loosely watching this group for some time as a CS-50 and CS-
60 owner. Seems I've just upgraded to a full member (;->), though my
object of desire is still located at the other end of the world.
So ... in anticipation of the beast that will soon be taking over my
little studio ... I'm looking for a keyboard stand for a CS-80.
Most of what I find in stores isn't fit for 200 pounds.
Can you recommend anything?
Doesn't even have to be dedicated for keyboards ...
I even think about making my own, with castors for moving it from the
wall for servicing and moving it back for playing.
Any ideas, any recommendations would be welcome.
JH.
Re: Keyboard stand for CS-80
2007-09-18 by blchrr@homecall.co.uk
Hey Juergen,
Welcome to the club mate.. :)
I thought i remembered you saying years ago that youd never get an 80!
I think this stand will do the job for you:
http://www.quiklok.com/catalog/?p=productsMore&iProduct=96&sName=Z-716
Hope you enjoy your 80, ive just had mine restored, will be picking it up
shortly...
Cheers,
Rob.
> JH.
Rob Belcher
www.myspace.com/duplx
2007-09-18 by erikfromhere
I mentioned it before in this group, I use pedestals (as used in
office-furniture) as stands for both my CS80's. Dimensions are: 60cm
height, 80cm length, 40cm depth. They have 4 casters (not too small)
so you can easily move the CS80 around. Besides, you can use the
drawers to store your manuals, parts etc. There is enough room left
for your legs and feet since the pedestal is at the flat part of the
CS80. When sitting in front of the CS80, the drawers open at the
left or rigt side to give you an idea. I placed some wooden bars
under the synth not to obstruct ventilation.
Good luck with restoring (do you have to ?)your CS80 when it gets
in !
--- In yamahacs80@yahoogroups.com, "dark_november2000" <jhaible@...>
CS-
my
my
> JH.
Re: [yamahacs80] Keyboard stand for CS-80
2007-09-18 by Fredrik Segerfalk
Congrats to your baby :)
I use this and it works well : http://www.thomann.de/se/millenium_ks2010.htm
Fredrik Segerfalk
www.segerfalk.com
www.analogsweden.com
> JH.
Thanks!
80!
There was a time when I was quite frustrated with CS-80. Driving to
Switzerland to pick one up, and then returning without it. In
retrospect, I should have bought it despite its unexpected flaws, the
prices for CS-80 going up and up.
Anyway - now I'll have one.
716
Thanks for the link!
it up
> shortly...
Mine has also been recently serviced, from the good hands of The Old
Crow, and I'll get it from him directly.
I'm so excited!
I only don't know how to tell it to my heavily modified - just
recently - Farfisa VIP 500 that she'll have to go, to make room for
something superior ... (;->)
JH.
60cm
small)
That sounds very close to what I have in mind!
I'll have to find something with the right height, though, to play
the CS-80 comfortably while sitting down.
> in !
It has just been serviced. I guess I'll have to re-tune it after its
voyage to Germany, and I'll have to re-connect the PSU for something
close to 230V.
220V probably was a factory option. My idea is not to use two 110V
windings in series, but a 110V and the 117V, if the topology allows
it. That would reduce stress on the PSU components and also reduce
heat a little.
Has anybody made such a 227V modification on his CS-80 sucessfully
yet?
JH.
> --- In yamahacs80@yahoogroups.com, "dark_november2000" <jhaible@>
and
> CS-
> my
> my
> the
> > JH.
Thomann! That was the first one I searched last night; their
headquarters are not far from my home. Strange that it didn't apear on
their German site. Or maybe I didn't even look closer because I had't
trusted an "X" shape stand to carry 100kg ...
Well, they say 100kg, and I'd gladly have some reserve, in case I
accidetially lean on it when I play in the night until until I fall
asleep. :)
JH.
In order to find the right thing (that might have slightly different
dimensions) - did I understand this right:
(1) You only need to support the (relative small) flat part of the
underside?
(2) The crews to open everything up are _not_ in th eflat part, but
all in the sloped part right?
(3) What's the exact distance between the screws (from left to right)
on the underside? (to avoid something in th estand to _just_
accidentially being the same width.
(4) Most important: What is the exact difference in height between the
flat underside (where the synth will rest on the stand), and the top
surface of the white keys?
I need (4) to calculate the height of the stand or pedastal including
casters, to achive my comfortable playing height. On my other synths,
I've optimized this by sawing off pices from the wooden legs I'm using.
With the CS-80, I'd rather know beforehand, so I can get it on top of
this right when it arrives.
If you, or anybody else, just has a measuring tape at hand, I would be
deeply grateful!
JH.
> underside?
Yes, the weight is at the back, the original steel support does the
same, it's bolted to the flat underside of the CS80.
but
Most are, I took the screws out so I can open the lid if I want to.
right)
If I remeber well: leave the inclined part free, than you can access
all screws
top
24 cm
I'm sorry, it's 14,5 cm !!
Re: [yamahacs80] Re: Keyboard stand for CS-80
2007-09-18 by JH.
Thank you!
JH.
To: <yamahacs80@yahoogroups.com>
Sent: Tuesday, September 18, 2007 5:24 PM
Subject: [yamahacs80] Re: Keyboard stand for CS-80
> underside?
but
right)
all screws
top
24 cm
Yahoo! Groups Links
2007-09-18 by JH.
Ok, thanks. That means I'll be looking for a stand (or will be building a
stand) that is only 59cm high, casters included.
I'm sure I'll find something like that.
I forgot to ask (in case I'll be constructing something myself): how deep
(front to rear) is the flat part?
JH.
Yahoo! Groups Links
deep front to rear) is the flat part?
it's 44 cm. Remember to make sure you leave some 2 cm ventilation-area
free inbetween the stand and the CS80.
By the way, I find the original stand too high to sit at and too low to
stand at...
2007-09-18 by JH.
That's almost what I have calculated as the ideal height for me after you
gave me the 14.5cm
bottom to keytop. (I checked: it's almost the same on my CS-50, btw.)
I calculated 59 cm - but that would be including casters and the wooden
bars.
And the bars go front-rear (40cm each), or left-right (80cm each) ?
JH.
2007-09-18 by Wavecomputer360
I´m sure it´s been mentioned already but Koenig and Meyer make a nice keyboard stand for heavier electronic pianos and the like which carries zp to, I think, 200kg, plus it has the option of adding another tier to it for another keyboard on top of the CS80. Check the Music Store or Thomann catalogues.
Ruka would be another choice...
Stephen
____________________________________________________________________
"Ambition makes you look pretty ugly, kicking squealing Gucci little piggy." (Thom Yorke/Radiohead -- "Paranoid Android")
Finally available: Stephen Parsick -- Traces of the Past Redux, reissued with three previously unreleased bonus tracks.
It´s out: [´ramp] & markus reuter -- "ceasing to exist", a gorgeous dark ambient album. available through our webshop at www.doombient.com
For info and audio, please visit the official [´ramp] website at www.doombient.com
  To: yamahacs80@yahoogroups.com
  Sent: Tuesday, September 18, 2007 1:44 PM
  Hey Juergen,
  shortly...
  Cheers,
  Rob.
  > JH.
  Rob Belcher
RE: [yamahacs80] Keyboard stand for CS-80
2007-09-18 by Synth80s
When I had my CS-80, I used my CP-70 as the stand.  I'd seen video of
Prince dancing on his CP-70 in concert, and though he probably only
weighs half of a CS-80 (maybe a buck twenty), he jumped around enough to
convince me that it would be sturdy.
Anyhow, the CS and CP made a nice looking couple for a time. :)
-Synth80s
2007-09-19 by David Rogoff
Yes - it was a nice setup until I took the CS80 away :^)    This is what
Jobson did with U.K., too.
Until I finally tracked down the original legs, I used a heavy duty X
stand, rated for 300lbs.  Unfortunately, something messed up on it.
About an hour before someone dropped off a CS80 at my house (it's still
there - I'm not sure when he's coming back from vacation!), I set it up
and just for fun put all my weight on it.  It collapsed, giving me some
nice bruises.  I'm still glad I did it - I don't want to imagine if we
had dropped the CS80 on it!
 David
I forgot to mention a great feature of the original legs. Since they
bolt onto the CS80, and the rear side of the bottom is curved, it
allows one person to move and setup a CS80 on a stand!  You just roll
the CS80 to where you want it and attach the legs while it's on its
side.  Then you just (carefully) lift from the back edge of the CS80
and roll it up on to the legs.
It's the only way I could handle the CS80 by myself!
 David
2007-09-19 by erikfromhere
They go from front to rear, there are some spots under the synth
without ventilation-gaps. These steel ventilation-parts look a bit
fragile to me...
I must admit, increasing the width of the pedestal above 80cm will
look a bit nicer (it will be more in line with the sides of the CS80,
but 80cm is just a standard dimension for these kind of
pedestals/containers. My job is in the office-furniture you see)
In my experience, use casters with a diameter of 60mm or more, else
the combination is too heavy to comfortably move around.
> JH.
Keyboard stand for two CS-50s
2007-09-19 by Richard Atkinson
On a similar theme, does anyone have any suggestions for a keyboard stand
to take two CS-50s?
I have recently bought two of these mini-monsters, and have all sorts of
ideas for using them together. I could arrange them on their original
stands at right angles to each other, but it would be much better to have
one CS-50 above the other.
Grateful for any suggestions!
Richard
2007-12-14 by dark_november2000
Replying to an old message, as now I'm actually building a wooden
stand / pedestal with casters, I have one specific question to Erik,
or anybody else who can answer this.
Is it ok to have these bars running *across* the vents?
They would only close a small part of them.
Question is, are they fitted flat enough into the bottom of the synth
that I can run a bar under them, supporting the whole weight of the
CS-80?
The benefit of this would be to place the bars exactly where the
original stand would be located, with a span of 91.5cm between them.
Otherwise, if I have to avoid the vents completely, I must place the
bars closer to the center, allowing 75cm width maximum.
What I plan to do is building a pedestal where the left and ride side
panels are elongated 10cm above the top panel. I's build them from
19mm multiplex (and could possibly double the 10cm above the top
plate to 38mm).
I just don't know whether to go for 75cm witdh (avoiding the leftmost
and rightmost vents), or wheter to build the pedestal with 90 ...
95cm width and going right across th events (obstructing a strip of
3.6cm of the 10cm wide vents).
What would you recommend?
JH.
(want to go wood shopping tomorrow; CS-80 should arrive next week.)
--- In yamahacs80@yahoogroups.com, "erikfromhere" <moogsynthex@...>
60cm
small)
> in !
and
> CS-
> my
> my
> the
> > JH.
2007-12-16 by erikfromhere
The original stand crosses some ventilation-sections partly too. You
can see it on the pictures in the user manual. So I guess it's fine to
have some wood there instead. The steel sections are a bit under the
surface of the Tolex, only the screwhead can stick out a little bit.
Nothing to worry about however. Using the exact same position as the
original stand is fine.
2008-01-24 by JH.
I've finally taken a photo of what I've built.
Taking up your *great* idea of using a pedestal, and combining it with an
integrated version of the wooden bars that allow ventilation.
http://launch.ph.groups.yahoo.com/group/yamahacs80/photos/view/b5ba?b=1&m=f&o=0
JH.
Sent: Tuesday, September 18, 2007 2:29 PM
in !
2008-01-25 by Rick
nice work.. wheels would be handy.. hurt my brother moving my CS last
week.. wimp
with an
> JH.
> From: "erikfromhere" <moogsynthex@...>
> in !
