DCO2 issues with JX-8P
2013-07-01 by zaphodbetamax
I have recently repaired a random reboot concern on my JX-8P by replacing the 7805 voltage regulator, and resoldering any possible cold solder joints in the power supply area such as the rectifier joints. A new random type issue has developed and I think it is a wire and or joint in the main board. Sometimes you can hear DCO2 cutting in and out while playing, and if you tap the keyboard case around the JX-8P logo, you can hear the DCO2 sound kick in and out, responding to my fingers tapping. It seems this would be a loose connection either on a solder joint, or one of the connectors, but does any technical people have any idea of where on the main board I should be looking, as this is a microphonic style random issue. Thanks Mark Pigott Sarnia, Ontario
