To: PolySix@yahoogroups.com
Sent: Tuesday, July 20, 2004 9:24 PM
Subject: Re: [PolySix] VCF cutoff quirkiness
I'll pull the cover and have a look. So if one filter was bad, the LED and it's
corresponding voice wouldn't work? Thanks for your extreme patience with a
not-so-technical person. I sincerely appreciate the help!
dizz
Quoting BrainSlayer <brainslayer@c-u-d.de>:
> there are six filter chips on the board. 1 for each voice. if you press one
> note it would only use 1 of them. if you release the note and pressing
> another key, another voice (not the same) will be played. so if you trigger 6
> keys in just a normal order you can identify the damage voice if. if you open
> the case you will see that a little led is lighted up for each voice that is
> played (so in fact there are 6 red led's bellow the filter chips)
> just enable the arpeggator and set a slow arpeggio speed. then you will see
> that the 6 led 's are blinking in a linear order. (this works only in poly
> mode, on unisono all led's are lighting up)
> Sebastian
> From: dizz@elitemofo.com
> Sent: Tuesday, July 20, 2004 6:38 PM
> Hi brainslayer,
> Thanks for the quick reply. Just to make sure I understand you correctly,
> If
> it were the chip itself I would hear it only in poly and not unison mode?
> Or,
> are you saying hold down six notes in poly mode and it would affect only
> one of
> the notes? My apologies if I'm being thick-headed here.
> dizz
> > if the filter chip would be the source of that issue, you would only hear
> it
> > at one of the six voices and not at all. so be sure it isnt the filter.
> > From: dizz662000
> > Sent: Tuesday, July 20, 2004 4:27 AM
> > Subject: [PolySix] VCF cutoff quirkiness
> > Hi, this is my my first post to this group. I bought a Polysix
> > recently realizing they're very old. Actually played guitar mainly
> > in the 80's but there was always a PSix in my basement studio.
> > Background: this unit had maintenance performed by Korg in the 80's
> > and the battery was lifted into a socket before any damage occurred.
> > It works pretty good except; I noticed some volume issues (not being
> > very responsive to cranking it up!) I believe I solved this issue by
> > working the volume pot a few times-maybe a scratchy pot in need of
> > cleaning. More importantly, there's an issue with the VCF cutoff. It
> > doesn't track well when at the lower freqs. When I move the knob it
> > sounds like it's dirty and cuts in and out. When it's stationary (not
> > moving) the freq cuts off where it should. Just to be clear, I can set
> > it any where and get the correct cutoff, it just takes some tweaking
> > at the lower end. This again sounds like maybe a dirty pot. I have
> > heard that the filter chip set may be going?? Not a tech head myself.
> > Sorry for being longwinded but I need to keep this dinosaur roaring!!
> > Any feedback would be appreciated
> > PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6
> > Yahoo! Groups Sponsor
> > ADVERTISEMENT
> > Yahoo! Groups Links
> > a.. To visit your group on the web, go to:
> > http://groups.yahoo.com/group/PolySix/
> > b.. To unsubscribe from this group, send an email to:
> > PolySix-unsubscribe@yahoogroups.com
> > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
> > [Non-text portions of this message have been removed]
> > Yahoo! Groups Links
> ADVERTISEMENT
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
ADVERTISEMENT
Yahoo! Groups Links
