Archive for polysix.
HALF D/A adjustment on KLM367 clone.
2018-09-28 by golbicali@yahoo.com
Open a new topic in order to not confuse readers:
I was not able to process correctly the D/A adjustment after a short on pin 1 and 2 of the IC33 DAC. VR6 and VR7 didn't had any effect.
-After replacing IC33 DAC and IC27 (4560) , VR6 and VR7 where active. And i was able to process a sort of D/A adjustment. i say a sort because it is like the adjustment is half done : The pots course works half, the MG speed is too slow event all the way up...
The official adjustment procedure says:
"TURNING VR7 CLOCKWISE,ADJUST SO THAT THE LIT LEDS SHIFT TO  (1 & 8) IN THE SHIFT FROM ( 2 & 7) to (1 & 8) ...
For me, it shift from  (4 & 8) to (1 & 8), the 8 never moves whatever i turn VR7 and VR6. It may be a good start point to investigate?
Then:
- tested with several New DAC, result is the same.
- replaced IC22(MCU) result is the same.
- replaced IC21 (LM13700) result is the same.
- replaced IC17 ( 4011) result is the same.
- replaced IC6 (LM393 comparator) result is the same.
- replaced D9. result is the same.
There are so many ICs that could have been damaged by the short on IC33 DAC pin 1 and 2 that I do not know anymore where to look?
Where to look if the D/A is done only half ?
What signal levels should i find on IC6 pin 1, 2, 3 when calibrating?
I'm a bit lost but, what is good is that i learn a lot at every step.
Any clue or explanation of how the D/A adjustment  works, is welcome.
Thank You.
