Polysix key Problem
2017-05-15 by joppemadsen@gmail.com
Hi all.
I'm new to the group. I have been a member og the Korg Mono/Poly goup for some years now, and I have very much appreciated the knowledge found there.
I seem to have a problem with my Polysix's keys.
I have installed the Kiwisix and the keyboard works perfectly over midi (a bit noisy with bad pots). All six voices are functioning.
Some of my keys are not responding. It is the same keys in each octave, so I guess it's a faulty IC on the key assigner board KLM 366? I have cleaned the keyboard contacts with alcohol, and that helped a little. But the dead keys remain completely dead.
Since all voices work with midi, does that then indicate that the key assigner is working as well?
Can I buy a keybed that fits the polysix somewhere? Is there a standard fit? Could I try with a Mono/Poly keybed?
Should I try to replace some digital IC's?
Thanks for all your help and your time.
Regards
Jeppe Madsen
