Archive for polysix.
P6 w/ kiwisix - sync midi to external clock
2017-01-28 by electronik22@yahoo.com
How do I do that?  I use Ableton Live and I would like to sync the P6 arpegiattor to Ableton's midi clock.  I've set up the midi in/out from the P6 to my PC (via midi-to-usb).  I must be doing something wrong as the P6 does not sync or allow the clock to be controlled by Ableton.
Thanks all!
Re: [PolySix] P6 w/ kiwisix - sync midi to external clock
2017-01-28 by Florian Anwander
Are you sure, that MIDI-clock is enabled for that MIDI-OUT in Ableton?
Re: P6 w/ kiwisix - sync midi to external clock
2017-01-29 by electronik22@yahoo.com
Thanks for replying!  Yes I made sure Midi out was enabled for both track and sync in Ableton.  I'm not sure what setting the P6 needs to be set to in its midi parameters.  I'm assuming midi sync internal/external needs to be turned on but I'm not sure what else (if anything else).
Another thing concerning with the P6 is that whenever I use the arpeggiator, after about 10 minutes of use, it starts cycling through tones almost like it is changing tone presets after about 10 seconds and moving to the next tone.  Then, when I turn off the arpeggiator, and hold down a chord on the keys, the notes will ring out like they should and then fade off and back on as if I pressed the keys again.  Strange!
Re: [PolySix] Re: P6 w/ kiwisix - sync midi to external clock
2017-01-29 by Florian Anwander
KiwiSix-manual Page 10:
Shift ON
Bank D
Programm 7
Adjust with the FX rate knob.
If Program 4 LED is lit, then the MIDI clock will sync with 16th notes.
I don't own a kiwisix, but I can read manuals.....
I think you should ask this on the Kiwitechnics Maillist.
http://groups.yahoo.com/group/kiwitechnics/join
2017-01-30 by Shane Wallace
Yes, I read the manual several times and setting midi clock to D7+Tone 1 (solid LED) means that it will sync to internal/external device.  That seems like the correct parameter to use.  Thank you for posting the kiwisix mailing list link- I will join that and see if there's something wrong with my synth or perhaps a firmware update is needed, etc.
"its all in the reflexes." -jack burton
On Sunday, January 29, 2017 5:40 PM, "Florian Anwander fanwander@mnet-online.de [PolySix]" <PolySix@yahoogroups.com> wrote:
Shift ON
Bank D
Programm 7
