Archive for polysix.
Crispy sound, anyone?
2015-05-26 by landemaine@gmail.com
Hello,
I received a Polysix, and I found that the sound is very crispy (read: unpleasant). Could you take a listen and let me know what you think, please?
http://nearly.free.fr/tmp/p6-crispy.mp3
The volume is far from clipping...
Is this normal?...
Thank you,
Charles.
Re: [PolySix] Crispy sound, anyone?
2015-05-26 by Florian Anwander
It is not normal. Appearently it is some distortion in the sum of all
six voices. I'd track the signal on the effects board.
Florian
Am 26.05.2015 um 14:54 schrieb landemaine@gmail.com [PolySix]:
> Hello,
> please?
> Is this normal?...
2015-05-26 by <backshall1@bellsouth.net>
Definitely not normal. It sounds like there is some clipping happening in some of the patches. Is it only when the chorus/phaser/ensemble is on? Does the Attenuator setting change it?
Don B.
Sent: Tuesday, May 26, 2015 8:54 AM
Subject: [PolySix] Crispy sound, anyone?
Hello,
Is this normal?...
Thank you,
Charles.
Re: Crispy sound, anyone?
2015-05-30 by landemaine@gmail.com
Hi guys, thanks for the tips! You're right, this happens when piling up several notes. I found out that the Attenuator pot is not working, and neither is the VCA mode (EG / Gate). There's definitely something wrong in the VCA section. I'll take it to my local electronician for repair.
Re: [PolySix] Re: Crispy sound, anyone?
2015-05-30 by florian anwander
Hello
Am 30.05.2015 um 11:24 schrieb landemaine@gmail.com [PolySix]:
The attenuator is not a potentiometer, but a multiposition switch.
Are you able to change the effect type (chorus/phase/ensemble) and to
disable it?
If not, then the ICs 34/35 might be the cause (or the control of these ICs).
Florian
2015-05-31 by landemaine@gmail.com
Florian,
Thank you. Yes, I am able to change the effect type (chorus/phase/ensemble) and to switch it off.
Charles.
---In PolySix@yahoogroups.com, <fanwander@...> wrote :
Hello
Am 30.05.2015 um 11:24 schrieb landemaine@... [PolySix]:
disable it?
Florian
