Index last updated: 2026-03-31 12:26 UTC
Switch replacement
Switch replacement
2003-09-29 by fargap
A couple of the key switches on my board (bank, program, arpeggiator
type) are a little squishy. One is actually quite tempermental. So
I'm thinking of replacing them. So what should I replace them with?
The switches have a removable keycap, an led, a chassis, and what
looks to be a tactile switch built in. Should I replace the entire
switch? I've seen a couple of "current" switches which look very
similar, but...
I've seen 12mm square tactiles mentioned as valid replacements, but I
can't figure out how they would work. Do they fit inside the little
keyswitch chassis somehow?
fargap
Re: [PolySix] Switch replacement
2003-09-29 by greg montalbano
Yes; desolder the LED, then it & the switch cap will come off, then the
switch itself can be desoldered & removed. Take care in handling the
switch caps -- once the plastic breaks, they're difficult to repair (&
impossible to replace, as far as I know).
I've obtained suitable replacement tact switches from Mouser Electronics &
Jameco -- they're fairly standard.
This is a fairly routine task for someone with soldering & electronics
experience -- should be VERY carefully approached by anyone else.
~G
At 07:55 PM 9/29/03 +0000, you wrote:
>Hi,
>similar, but...
>Thanks,
>fargap
>Yahoo! Groups Sponsor
>ADVERTISEMENT
>To unsubscribe from this group, send an email to:
>PolySix-unsubscribe@yahoogroups.com
>PolySix "Digiest" Page:
><http://www.acc.umu.se/~amber/Poly6>http://www.acc.umu.se/~amber/Poly6
>Your use of Yahoo! Groups is subject to the
><http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service.
Re: Switch replacement
2003-09-30 by fargap
Thanks, Greg. I'll get a few tactiles and try replacement. I've been
slinging solder so long, I kinda like the fumes. :)
I wish a complete replacement switch existed. A couple of my switches
are, for lack of a better description, a little droopy. The caps snap
onto a little plastic actuator, and the the actuator itself seems to
have grown a little lazy. I could glue the caps to the actuator, and
that would probably help some - but I hate to do anything permanent.
I notice DigiKey carries a similar switch, part of the ITT Digitast
line, but I bet it's not a direct replacement. Mouser also carries a
similar switch - from E-Switch, one of their 5500 series - but again,
I don't think it could be a drop-in replacement.
Thanks again,
fargap
--- In PolySix@yahoogroups.com, greg montalbano
then the
Electronics &
electronics
> ~G
> >Hi,
arpeggiator
> >similar, but...
but I
> >Thanks,
> >fargap
> >ADVERTISEMENT
6
