Polysix 100/120V to 220/240V conversion - Swapping transformer?
2014-12-25 by stalinjohansen@yahoo.com
Archive for polysix.
The fuses etc. in the Polysix says they're all rated for 250V, so my guess is that changing the transformer is all that's needed. Anything else that will need to be changed as well?
2014-12-29 by stalinjohansen@yahoo.com
2014-12-29 by Malte Rogacki
2014-12-29 by Johannes Hausensteiner
> Measured the AC-voltage coming out from the step-down converter, andThis is indeed quite high (+27%)
> it's 127V! (126.8V) That's no good.
> Could someone please list the effects on a Polysix (or any synthSince it is a simple AC transformer it will transfer the primary voltage
> /audio equipment for that matter) rated for 100V when the incoming
> voltage is +27V?
> I've read that a transformer receiving excessive voltage willThe overvoltage will cause excessive heat mainly on the power
> overheat, but will components literally die from this? What
> components are affected by long term use of +27V of excessive voltage?
> Also measured the AC-output from the wall socket today. Its 235V.This is perfectly OK and normal. The nominal voltage is 230V +10/-15%
> Should i get a 225VA or a 250VA transformer for the Polysix? Can'tThis is a misunderstanding. The physical unit "VA" means "Volt Ampere",
> see that the local store sells any 240VA transformers.. only 225VA
> and 250VA in that VA-range.
> Could someone please list the effects on a Polysix (or any synth/audio
> equipment for that matter) rated for 100V when the incoming voltage is +27V?
> I've read that a transformer receiving excessive voltage will overheat,
> but will components literally die from this? What components are
