Non-working attenuator
2014-12-23 by tuk88@rocketmail.com
Hi everyone,
at first thank you for all these topics and knowledge which are very important for every polysix user (and repairer). With all these messages, the polysix will still live in some years :)
I post this topic due to my non-working attenuator. I'm pissed of by this one because I check everything I can (following differents topics found here).
At first the KLM-367 was changed by a clone. I build everything and the attenuator never worked with the new card. I don't know if it worked with the old acid eaten card.
- So, I checked P10, P11, P12, P13 and D03 conductivity, between KLM-370 and KLM-367. Everything is OK.
- I checked the presence of D03 on the different chips on KLM367. It's OK too.
- I checked the conductivity of P10, P11, P12 and P13, between connector of KLM 367 and 8048 uC. OK.
- D03 and the others are presents on CN10 of KLM367.
- Every diode of attenuator swich are OK.
- D03 signal seems to be OK.
So, now I'm lost...
Has anybody and idea, where does this issue can come from ?
Thank you a lot !
Lucas
So, now I'm lost...
Thank you a lot !
Lucas
