Archive for polysix.
Volume fluctuations correlated to the filter resonance
2014-09-28 by num_si@yahoo.com
Hi all!
First I'll give further explanation of the problem:
If the cutoff is completely open and the resonance turned all the way down, everything sounds as it should. With the resonance turned up I sometimes have irregular volume fluctuations occuring. They dont occur right away, sometimes everything works fine for 10-30 minutes until the volume drops out.
Also these fluctuations are not always the same.
In most cases I am triggering my Polysix via Midi from Ableton and Ive noticed two different scenarios:
1. The volume varies pretty fast, for example if I have a loop with 4 notes running, none of them will have the same level.
2. The volume decreases, then stays at this low level for some time and then increases back to the normal level.
I sent the Polysix to a synth repair service here in Germany, and this week the guy told me he couldnt detect anything and will send it back to me.
The P6 was purchased first-hand, about 2 years ago. I dont know if it ever was calibrated, at least the original battery is still in there, and no, it's not leaking ;)
It is my first vintage synth, so I have absolutely no experience. Is it possible that a proper calibration could fix this problem or is it more likely a damaged chip/circuit board/jack or whatever?
Any help would be really appreciated!
Tilman
Re: [PolySix] Volume fluctuations correlated to the filter resonance
2014-09-29 by Chromatest J. Pantsmaker
A couple things:
First-Hand to me means "brand new".  Second-Hand would be used.
I've never seen or heard likely evidence that *any* Poly6 has an original battery in it that has not leaked at this point.
I'm guessing that the original battery was replaced with the same brand of rechargeable battery and that the original leaked and has done damage.  I'm guessing that when the repair was done, they couldn't find what was causing the problem, so the last owner sold it.
Try this:
Activate arpeggio (light on) with latch switch on, one octave.  Press the same note 6 times in a row.  Set VCA Mode switch down (not EG), Waveform fully counter-clockwise, everything MG fully counter-clockwise. Let this run for a while (30-60 minutes).  Does the volume vary?
Out of curiosity, what MIDI retrofit does it have in it?
On Sat, Sep 27, 2014 at 8:05 PM, num_si@yahoo.com [PolySix] <PolySix@yahoogroups.com> wrote:
Hi all!
I sent the Polysix to a synth repair service here in Germany, and this week the guy told me he couldnt detect anything and will sen! d it back to me.
Tilman
2014-09-30 by num_si@yahoo.com
With first-hand I meant Ive bought the synth from the first owner, I even got the purchase receipt from 1984 ;)
Your guess regarding the battery cannot be true, because I bought the synth nearly 2 years ago and the first 1 1/2 years it worked very well...
I'm now waiting for the guy to send it back, but when I have it I will try the thing with the arpeggio.
I've installed the CHD midi retrofit.
Cheers
