Archive for polysix.
I killed my PolySix, help!
2014-04-28 by <jeremy.pisani@gmail.com>
So, I did a stupid thing. I got my PolySix a few years back, and it had the leaky battery issue. I sent the board off to be fixed by Old Crow's synth shop, and after that it was working great, except for the buttons being finicky, and the Hold button didn't work at all. After a lot of procrastinating, I finally ordered some new switches and went to work desoldering & replacing the buttons.
At first I checked to make sure the synth was still functioning correctly after I replaced each button, but after 5 or so I felt confident enough to keep going without checking (I'm kicking myself as I write this). When all was said & done I powered it up and it's behaving like it did when I first got it. When powered on, the Write & Manual buttons light up, as well as the Bank C, Poly, and Program 3 & 5-8 buttons. I can switch between Poly/Unison/Chord Memory & Hold buttons with no problem, but it doesn't affect the sound. None of the knobs seem to affect anything either.
 I did a lot of the desoldering without putting something over the circuit boards to protect them from solder flecks, and I'm guessing maybe something got fried when I powered it on, but honestly, I don't know. I did a little poking around with a multimeter & got the following results:
Power supply voltage:
4.2/-4.2
14.6/-14.6
All ICs on the KLM-376A are reading 4.8v except for the following:
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
Continuity between the previously repaired traces seems to be fine. Any ideas?
Re: [PolySix] I killed my PolySix, help!
2014-04-29 by Bob Grieb
The LEDs that you say are working are controlled by the key assigner MCU.
The other LEDs are controlled by the MCU on the KLM367 bd.  Can you get into
the DAC calibration mode by flipping the switch on the KLM367?   At least that would show that the MCU is executing code.  (I'm not suggesting that you calibrate the DAC, just see if the CPU will enter that mode)  Do you have an oscilloscope?   The 4.2V value seems low.  How much confidence do you have in your DMM?
Many of the chips you are probing are analog, and have power on different pins.   Please
just focus on the digital IC's.   Maybe you need to download the service manual and take a look at the schematics?   Usually the problems with the KLM367 have to do with IC31, 30, and connections to the front panel on CN06.   If you have a scope, what is the waveform like on pin 32 of IC22?   (Be careful not to short to an adjacent pin when probing)
    Good luck,
        Bob
From: "jeremy.pisani@gmail.com" <jeremy.pisani@gmail.com>
To: PolySix@yahoogroups.com
Sent: Monday, April 28, 2014 6:56 PM
Subject: [PolySix] I killed my PolySix, help!
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
2014-05-01 by Jeremy Pisani
Hey Bob,
Thanks for the reply! Haven't had a chance to look at the PolySix since I sent this, but hopefully I'll be able to get back to work on it in a day or two.
I haven't attempted to get into the DAC calibration mode; if I remember correctly, the service manual asks you to connect a 56k dummy resistor to the 2 prong connector on the power supply, and I don't have any test clips for the time being...will give it a shot once I pick some up.
To answer a couple of questions you had: I don't have an oscilloscope, unfortunately, but I'm definitely going to pick one up, as I have another synth here that I'd like to calibrate as well (Yamaha CS-5). The multimeter I have is good quality and practically new, so I'm pretty convinced the readings are accurate. Any idea why the voltages would be so low?
    Good luck,
        Bob
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
2014-05-01 by Bob Grieb
Check the voltages right at the power supply.   The 56K resistor is for the low voltage
sense test, I think, not the DAC cal, but you are supposed to get the power supply
voltages correct first.   If the supply voltages are low, it's either an issue with the supply,
or something drawing too much current.
Sent: Thursday, May 1, 2014 3:47 PM
Subject: Re: [PolySix] I killed my PolySix, help!
Hey Bob,
    Good luck,
        Bob
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
Sometimes a DC voltage will read low because it has a lot of ripple
on it.   If you have a bad filter cap, it could cause a volt of ripple
on the 5V supply, which would cause it to read low.  If the -5V supply
is designed to match the +5V supply, then it will drop too.
A scope would make checking for ripple very easy.
   Bob
Hey Bob,
    Good luck,
        Bob
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
2014-05-02 by Jeremy Pisani
Thanks again for your help. Here's the values I got after doing the power supply calibration:
+15V: 15V
-15V: -15.06V
+5V: 4.82V
-5V: -5.01V
VR2 is all the way clockwise, I can reduce the voltage, but can't get more than 4.82V out of it.
Tried the D/A calibration procedure in the service manual, but the LEDs stayed the same.
   Bob
Hey Bob,
    Good luck,
        Bob
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
2014-05-02 by Bob Grieb
OK.   Seems like there may be an issue with the 5V supply.
Possibly a bad filter cap in the power supply, or maybe something
that is drawing lots of extra current.  You can try putting your meter
in AC mode and measuring the supplies to see how much ripple
is one them.   I don't think the CPU on the KLM367A bd is running.
Reset to that chip is pin 4.   If the 5V is too low, or is pulsing low due
to excessive ripple, it may be resetting that CPU over and over.
I would see what you measure with the DMM on pin 4 of IC22, being
careful not to short to any adjacent pins.     The reset circuit is looking
at the 5V supply, so if that is too low, the CPU will be held in reset.
    Bob
To: polysix <PolySix@yahoogroups.com>
Sent: Thursday, May 1, 2014 9:04 PM
+15V: 15V
-15V: -15.06V
+5V: 4.82V
-5V: -5.01V
   Bob
Hey Bob,
    Good luck,
        Bob
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
I'm getting 4.7V on pin 4 of IC22. Not sure how to measure the ripple with the DMM, I have it in AC mode, but I just get a low reading (2v or so) which quickly goes down to zero. Looks like now might be a good time to invest in a scope...
    Bob
+15V: 15V
-15V: -15.06V
+5V: 4.82V
-5V: -5.01V
   Bob
Hey Bob,
    Good luck,
        Bob
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
It would certainly make things a lot easier.   Troubleshooting a processor-based system with a DMM is pretty tough.
Hard to say if 4.7 instead of 4.82 means you are getting reset pulses.  It's possible.
A low AC reading on the DC supplies is good.   Normally the ripple at the input to
the regulator would be removed by the regulator.   The exception is when the filter cap
has lost much of it's value due to age and the voltage at the input to the regulator is dropping below the minimum value that it needs.   A 7805 5V regulator needs something like 6 to 6.5V to put out 5V.  (Depends on current, temp, etc)   Anyway, having a scope
available would be a big help for troubleshooting.  Even an old boat-anchor type with at least 60 MHz bandwidth would be a lot better than nothing.   Digital storage is very useful in some situations, but adds cost.
Bob
Sent: Friday, May 2, 2014 1:22 PM
    Bob
+15V: 15V
-15V: -15.06V
+5V: 4.82V
-5V: -5.01V
   Bob
Hey Bob,
    Good luck,
        Bob
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
2014-05-05 by Jeremy Pisani
Well, I've been looking into a scope, but really the only thing within my budget would be something like this:
I know you recommended a scope with at least 60MHz bandwidth; would this one not get the job done? My only other idea at this point is replacing the MCU chip on the off chance that it went bad, replacements are really cheap on ebay...
Bob
    Bob
+15V: 15V
-15V: -15.06V
+5V: 4.82V
-5V: -5.01V
   Bob
Hey Bob,
    Good luck,
        Bob
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
2014-05-06 by Bob Grieb
Hi Jeremy,
   I'm a little bit of a "scope snob", so maybe not the best one to ask.   Certainly the
Hantek device would be a lot better than nothing.   I would suggest troubleshooting
instead of just replacing a chip and hoping.   There are lots of things that could cause
the MCU to not do the right thing.  If you buy some sort of scope, it will be useful for
other things as well.
    Higher bandwidth would be better, but having storage is nice.    The general rule is that
for looking at a square wave, to get a good display you need bandwidth that is ten times the
frequency.   So you may be OK with the signals in the PolySix, since the CPU divides the
clk by 15 or so for the instruction cycle.
     How much are the replacement CPU's for the PolySix on ebay?  I haven't noticed them.
You would need a chip that has the Korg code in it, of course, not just any 8049 chip.
     Bob
Sent: Monday, May 5, 2014 6:01 PM
Bob
    Bob
+15V: 15V
-15V: -15.06V
+5V: 4.82V
-5V: -5.01V
   Bob
Hey Bob,
    Good luck,
        Bob
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
2014-05-06 by Jeremy Pisani
OK, I might go for the USB scope then. I did notice a couple of things today that seem important; the following keys don't seem to be lighting up the diodes on the key assigner board:
D1
A#1
F#2
D3
A#3
F#4
D5
I remember reading a blog somewhere that told you how to troubleshoot this, but can't find it at the moment...
And while inspecting the board around the key assigner, I noticed a small black component that was bent back almost at a 45 degree angle. When I (gently) straightened it, it snapped off completely. It turned out to be a crystal resonator (X1 on the KLM-366B schematic). Could this be part of the issue?
On Mon, May 5, 2014 at 9:01 PM, Bob Grieb <bobgrieb@yahoo.com> wrote:
Hi Jeremy,
     Bob
Bob
    Bob
+15V: 15V
-15V: -15.06V
+5V: 4.82V
-5V: -5.01V
   Bob
Hey Bob,
    Good luck,
        Bob
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
Hi Jeremy,
   X1 is a "ceramic resonator" which functions like a crystal in the oscillator
of the 8049, but is less expensive and less accurate.   I am sure that it was working
OK before it snapped off, or none of the keys would work and the lights that you
said were working would not have been.   If there is enough lead length left to tack
wires onto that resonator, just put it back.   Otherwise I can help you pick a replacement.
It's NOT a crystal, but you could use a crystal if you change the two capacitors that are
in that same circuit.
     The keys that you mention as not working are all connected to P12.  The keyboard
is an 8x8 matrix.   One end of each key connects through a diode to one of the data bus
pins.   The other end connects to one of the Port 1 pins.   Seems like you have an issue
with P12 connection somewhere.  That's P12 on the key assigner CPU.   Completely
separate from the KLM367.
     You'll need to deal with the ceramic resonator before doing any more tests.
I would use your ohmmeter to check the connections from the CPU on the KLM367
to other places that it connects to.   Especially the two AND gate chips that get damaged
when the battery leaks.   Also, check the connections to the SRAM.  You will need
to remove the battery or it will mess up you resistance measurements.
       Bob
Sent: Tuesday, May 6, 2014 3:06 PM
D1
A#1
F#2
D3
A#3
F#4
D5
Hi Jeremy,
     Bob
Bob
    Bob
+15V: 15V
-15V: -15.06V
+5V: 4.82V
-5V: -5.01V
   Bob
Hey Bob,
    Good luck,
        Bob
4.2/-4.2
14.6/-14.6
IC14: 3.5v
IC20: 3.6v
IC21: 4.1v
IC25, IC32: 4.1v
IC34: 4.6v
