Archive for polysix.
Mylar caps on the sample-hold circuits on KLM-367
2013-05-03 by chipaudette
Hi Folks,
Some of you may know that I've replaced the keybed on my Polysix. The new keybed has a long metal cross-bar that sits a little lower than the one on the stock keybed. The new keybed is running into the tall 0.047uF Mylar caps that are standing tall from the KLM-366. Specifically, I'm talking about C31-C36 that are the caps that hold up the sample-and-hold output from IC29.
Being too tall, I'm thinking about replacing them. They're listed as 50V Mylar caps. Would it be OK to replace them with 50V ceramics instead? The ceramics are WAY smaller and would allow my new keybed to fit easily.
The signals being held by these caps is only used for the keyboard tracking of the VCF, so it's not like I need a cap with ultimate fidelity. I think that I need a cap that holds its DC value very well (which is the point of the S-H).
Would a ceramic be OK here?
Chip
RE: [PolySix] Mylar caps on the sample-hold circuits on KLM-367
2013-05-03 by backshall1
According to Analog.com
http://www.analog.com/library/analogDialogue/Anniversary/21.html, you should
be using any of the "poly" (polystyrene, polypropylene, Teflon) types for a
sample and hold circuit, since a ceramic cap has considerable dielectric
absorption which can cause a type of charge memory that can cause errors in
hold level. Some polystyrene caps can be rather tall, so you would have to
choose carefully. The old mylars look like they are about 10mm high. The
caps I'm using on the clone boards are about 8mm, so there is not much
difference. How much clearance do you need for the new keybed? If the old
caps weren't soldered so close to the board, you could just bend them over
so they would lie flatter.
Don B.
_____
From: PolySix@yahoogroups.com [mailto:PolySix@yahoogroups.com] On Behalf Of
chipaudette
Sent: Friday, May 03, 2013 12:05 PM
To: PolySix@yahoogroups.com
Subject: [PolySix] Mylar caps on the sample-hold circuits on KLM-367
Hi Folks,
the S-H).
Chip
Re: [PolySix] Mylar caps on the sample-hold circuits on KLM-367
2013-05-03 by Murray
no, don't use ceramic. Why don't you move the existing ones to the other
side of the board?
Just a thought
MH
> should
> for a
> errors in
> Don B.
> _____
> From: PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com>
> [mailto:PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com>] On
> Behalf Of
> chipaudette
> To: PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com>
> Hi Folks,
> Mylar caps
> IC29.
> tracking
> the S-H).
> Chip
Kind Regards<br>
Murray<br>
murray@paintingwithsound.co.nz<br>
www.paintingwithsound.co.nz<br>
Re: Mylar caps on the sample-hold circuits on KLM-367
2013-05-04 by chipaudette
Whoa. Other side of the board? There's a cool idea!
Chip
> side of the board?
> Just a thought
> MH
> > should
> > for a
> > errors in
> > Don B.
> > _____
> > Behalf Of
> > chipaudette
> > Hi Folks,
> > Mylar caps
> > IC29.
> > tracking
> > the S-H).
> > Chip
> Kind Regards<br>
> Murray<br>
> murray@...<br>
2013-05-06 by chipaudette
It turns out that there's not enough space under the board for these tall Mylar caps. But, once I got access to the underside of the board, I saw that the caps did have a little extra length on their legs on the bottom side of the board that I could loosen them up with my soldering iron, push them so that they stand a bit taller, and then simply bend them over so that they are out of the way.
Now they lay a bit flatter, which is just enough to let my new keybed sit down at the height that it's supposed to. Yay!
Pics coming a bit later...
Chip
> Chip
> > side of the board?
> > Just a thought
> > MH
> > > should
> > > for a
> > > errors in
> > > Don B.
> > > _____
> > > Behalf Of
> > > chipaudette
> > > Hi Folks,
> > > Mylar caps
> > > IC29.
> > > tracking
> > > the S-H).
> > > Chip
> > Kind Regards<br>
> > Murray<br>
> > murray@<br>
2013-05-08 by chipaudette
If you're interested, here are some pics of how bending over the caps solved my problem...
http://synthhacker.blogspot.com/2013/05/polysix-bending-over-capacitors.html
Chip
> Chip
> > Chip
> > > side of the board?
> > > Just a thought
> > > MH
> > > > should
> > > > for a
> > > > errors in
> > > > Don B.
> > > > _____
> > > > Behalf Of
> > > > chipaudette
> > > > Hi Folks,
> > > > Mylar caps
> > > > IC29.
> > > > tracking
> > > > the S-H).
> > > > Chip
> > > Kind Regards<br>
> > > Murray<br>
> > > murray@<br>
