Archive for polysix.
Please don't tell me battery leak.
2013-03-28 by pechnatunkagain
I'm also new here - so Hello Everybody!
I've been overseas - away from my Poly for almost 2 years...
I went to a lot of trouble when storing it - wrapped in plastic with moisture absorber sachets then lots of foam, bubble wrap and cardboard box.
Before I left I was going to take the battery out but was told on Gearslutz that it wasn't necessary as my Poly had already got the Orange safe Varta battery installed.
I've now returned and my Poly doesn't seem to respond to any knob movements and button presses - sometimes patch lights change by themselves - I read this is a symptom of battery leak.
Even before I left I vaguely remember having similar issues, but it would fix itself after a while. So there is a chance that the leak was there and the previous owner just replaced the battery without cleaning before selling to me.
1. Does this sound like battery leak?
2. Can the orange (is it Ni-Cad?) battery also leak?
3. Or could it be from an initial leak and has deteriated more while in storage.
I have some photos but can't see how to post in this message - I'll try and put them in the photo section under "Battery Corrosion?"
Thanks in advance for any help.
Vic
RE: [PolySix] Please don't tell me battery leak.
2013-03-28 by backshall1
From the photos, this board does have some battery leak damage, and it looks
like quite a bit of repairs have been done already. The original board only
has 3 IC chips that are in sockets (CPU and the two 13600 chips). Somebody
has removed quite a few others and put them in sockets. The orange battery
might be okay (still at approximately 3.6v ?) but the old leak might
continue to cause the board to deteriorate.
Don B.
_____
From: PolySix@yahoogroups.com [mailto:PolySix@yahoogroups.com] On Behalf Of
pechnatunkagain
Sent: Thursday, March 28, 2013 6:50 AM
To: PolySix@yahoogroups.com
Subject: [PolySix] Please don't tell me battery leak.
battery installed.
to me.
storage.
Vic
Re: Please don't tell me battery leak.
2013-03-28 by alesisfusion8hd
I had a NiCd leak on my Trident MKII; the corrosion also caused chips to have bad contacts with their sockets. Check.
Also, you have to stabilize the corrosion. Have been told cleaning the boards with baking soda is efficient; I've done this, and so far so good. Wash thoroughly and dry with hair dryer.
HTH
Francois
> Don B.
> _____
> pechnatunkagain
> Hi,
> battery installed.
> to me.
> storage.
> Vic
Re: [PolySix] Re: Please don't tell me battery leak.
2013-03-28 by Peter Mörck
The baking soda fix myth should be killed :)
Baking soda is a base. The electrolyte in NiCad batteries is alkaline, i.e. a base.
I can't see how a base would remove a base, other than diluting it perhaps if the concentration is lower, but I don't think that's the point.
I guess it stems from the assumption that all battery electrolyte is acidic, as in car batteries.
It is probably the _cleaning_up_after_ putting baking soda on that helps, not the soda itself.
Diluted vinegar (being acidic) would probably be better to neutralize the mess after a leaking NiCad battery if it is "fresh", but I think the key is to wash the electrolyte leftovers off. Water would probably work fine, but isopropyl alcohol might be preferable.
In particular, if neutralizing with an acid, you definitely want to wash it afterwards, or the acid will attack what the electrolyte missed :)
If it has corroded metal already, you should remove that stuff mechanically.
That's my firm conviction at least :)
BR,
Peter
Sent: Thursday, March 28, 2013 1:53 PM
Subject: [PolySix] Re: Please don't tell me battery leak.
HTH
Francois
> Don B.
> _____
> pechnatunkagain
> Hi,
> battery installed.
> to me.
> storage.
> Vic
