Archive for polysix.
Trannies for Jed's Board
2013-03-05 by raisinbag69
Ok I'm almost finished my rebuild of battery corroded board using Jed's replacement. All that is left are transistors to solder in. Following his BOM it calls for 3904 and 3906 for Q2,4,5. I have plenty of those but was wondering if reusing the C2785 for q5 and A1175 for Q2,4 would make it work any better?
Also, in Q1 on original board, I have a 2sk30GR. Bom says it is supposed to be a 2N3819. Can I use a 2sk30 on the Jed board for Q1? I have a bunch on hand OR can use the one on old board. (BOM says try a 2n7000)
I am mostly curious what has worked for other people. it is just as easy for me to desolder old ones as it is to pop in 390x and a 2sk30.
RE: [PolySix] Trannies for Jed's Board
2013-03-05 by backshall1
You must be very careful using 2sc or 2sk transistors in place of 2N. The
pins are usually different. EBC on 2N and ECB on 2SC. If you are prepared to
install these with crossed legs, they can be used.
We did notice a problem with the 2N3094 for Q5. On the first note you press,
there is no MG delay when there should be. All subsequent notes have the MG
delayed as they should. If you stop playing for a few seconds, the next note
will not have a delay on the MG. Very strange. We fixed it by reusing the
2SC945 from the old boards. I notice you have a different transistor in Q5.
I guess you will have to try both your old transistor and a 2N3094 to see if
there are any strange delay problems. I haven't heard anything good or bad
about the other transistors. The 2SK30GR should be fine as long as you can
find a pin-out diagram for it, or trace the old board back to see what pin
is connected to what.
Don Backshall
_____
From: PolySix@yahoogroups.com [mailto:PolySix@yahoogroups.com] On Behalf Of
raisinbag69
Sent: Monday, March 04, 2013 8:33 PM
To: PolySix@yahoogroups.com
Subject: [PolySix] Trannies for Jed's Board
any better?
Re: Trannies for Jed's Board
Thanks Don, I'll trace legs on old board and try route of using old ones. I think I have 2sc945 here as well, so I can always go that route if need be.
Cheers and thanks for the 390x heads up
DAve
> Don Backshall
> _____
> raisinbag69
> any better?
> Thanks
2013-03-06 by raisinbag69
Thanks. Board seems to be functioning though I gave to spend some time calebrating. Only thing I'm uncertain about is test switch. Which way does it go. One side says "open" and i assume when switch is depressed on the open side the contact is broken. So do we put "open" on the test side or no side? Worst is I desolder. Was so excited I didn't pay attension when I popped it in.
> Don Backshall
> _____
> raisinbag69
> any better?
> Thanks
