Index last updated: 2026-03-31 14:03 UTC
Octave Switch not working. Need a little bit of help to locate the problem.
2012-12-17 by lordoid1
Hey guys,
I have a problem with my beloved Polysix. The Octave switch died. My Polysix was repaired years ago from battery leakage. It worked flawlessly untill this day so I don't think the problem are after-effects from the battery disaster.
I replaced the complete Switch Board with a spare part but the problem was still there.
Then I checked at IC28 on board KLM367 if the Switch responds and gives the appropriate voltage settings. Everything is OK!
I also checked the cable which runs from KLM367 with connector 5 to KLM366. Seems fine.Nothing is loose.
Now I'm a little bit lost in locating the problem.
It would be great If you guys can give me some tips.
Greeetings from Germany,
Stefan
Re: [PolySix] Octave Switch not working. Need a little bit of help to locate the problem.
2012-12-18 by Johannes Hausensteiner
Does the Waveform switch work?
Is it both in Manual mode and saved patches?
There might be the connection on KLM-367 to connector CN06/pin3
interrupted. You can check with a beeper or Ohmmeter: KLM-369/Octave
Switch/middle pin to KLM-367/IC31/pin6.
On 2012-12-17 17:26, lordoid1 wrote:
> Hey guys,
> Stefan
Re: Octave Switch not working. Need a little bit of help to locate the problem.
2012-12-18 by lordoid1
Hey Johannes,
jeverything on the Polysix works except this OctaveSwitch. Waveform Switch is OK. I can change waveforms.
Thanks for the tipp. I will check this.
Greetings,
Stefan
Hey guys,
Stefan
Yahoo! Groups Links
Re: [PolySix] Re: Octave Switch not working. Need a little bit of help to locate the problem.
2012-12-19 by Johannes Hausensteiner
Check if the signals from KLM-367/IC28/pin3 ans 9 arrive at KLM-366/IC6/
pin1 and pin39. This is how the Programmer MCU tells the Key Assigner
MCU how to set the octave.
Good luck!
On 2012-12-18 23:41, lordoid1 wrote:
> Hey Johannes,
> Greetings,
> Stefan
> Hey guys,
> Stefan
