Hi group
My P6 is seriously noisy - a very noticeable hiss. Your classic noisy op amp type symptom.
Is the P6 known for fried op amps / op amps on way out?
(I've tried the foil insulator trick, but that hasn't helped the noise - indeed turning effects OFF makes no difference, so not the effects board)
The hiss/hum is worse when the attenuator is on lowest or highest settings.
-4 is just about usable.
Is it likely something on the KLM-370 board that's on its way out?
Could IC14051 be to blame?
Should I consider a recap? If so, total recap or just certain boards?
Any help / advice appreciated
Cheers
