Re: [!! SPAM] [PolySix] Simplest unit to trigger arp?
2012-10-02 by Peter Mörck
Hi, Triggering the arp is one thing. Doing a certain pattern is a completely different thing. If you're just looking for triggering then whatever that can handle S-trig will do. I don't use dedicated hardware sequencers, only Cubase, so I have no idea what's available. If you're looking to play specific patterns I'd say it's best to install a MIDI interface. Anyway, the bassline in enjoy the silence is more than just triggering the same sound. It's changing the filter cutoff freq on each note (whatever instrument they used. I've heard different things). So you'd need to trigger the arp in an irregular way, as well as control the VCF FM input with the sequencer, if that song your goal :)
To: PolySix@yahoogroups.com
Sent: Tuesday, October 02, 2012 3:02 PM
Subject: [!! SPAM] [PolySix] Simplest unit to trigger arp?
Hi, I'm looking for a very simple device I can use to trigger the arpeggiator on my polysix. Does such a unit exist?
All i want to do is trigger the arp so it does a certain pattern when I hit the note (an example being the bass line for Enjoy the Silence / Depeche Mode) is there an extremely simple arp trigger? Just a device where you can setup that send click sounds to the synth for which the arp will follow?
Btw, very stoked about this group!
