Index last updated: 2026-04-03 22:22 UTC
Polysix low tune problem on one voice
2012-09-11 by jimberlinp6
 I'm new to the board and have already found so much of the info here very helpful!
I'm fixing up a Polysix for the first time and have a problem when trying to tune the first voice (Unit 0). It's fine in the high register but when tryin to set the low octave the one voive is much lower then it should be (and the rest of the voices).
VR10's range for that voice doesn't nearly reach the pitch it should be. What might be causing the problem? Everything else works fine on this thing and it was originally bought calibrated. It was fine for about two months and then this started all of a sudden (the voice being way out of tune).
I have swapped SSM chips in and out of that voice but it changes nothing so they must be fine. Any help would be really appreciated!
Thanks a lot,
Jim
