Index last updated: 2026-03-31 18:47 UTC
hello a problem on a Polysix klm366B setting accuracy of notes on each octave
2012-06-10 by Vavasseur Philippe
and this is the first time I see this problem
when I make an adjustment of do on the 2nd octave
back 3rd octave sounds Re
every note is decale I change the iC that are around the conversion and nothing changes I understand why
if someone has already come and how the solution thank you
philippe
Re: hello a problem on a Polysix klm366B setting accuracy of notes on each octave
--- In PolySix@yahoogroups.com, "Vavasseur Philippe" <philippe.69@...> wrote:
> philippe
>in regardents I see that we speak of PC1> luck to VTL5C3
VTL5C2
R93
and what exactly is the proper fit til a photo to see between 5 and pin the old new 4-pin mounting
