Index last updated: 2026-04-03 01:39 UTC
Noise in my soup
Noise in my soup
2012-01-31 by bigpeeet@rocketmail.com
Does anyone else have a problem with noisy outputs?
I'm aware of two remedies: the insulation mod for the fx board described by Johannes, or re-capping. I have a really noisy couple in my possession at the moment, and unfortunately interference with the fx board isn't the issue for me. One has been re-capped recently too, so I'm striking that off the list.
While I really love their sound, they're both practically unrecordable for anything pro without a really good gate, and even then…
Anyone had success reducing noise, or have ideas about how to reduce/eliminate it?
Re: [PolySix] Noise in my soup
2012-01-31 by Mike
What type of noise?
Hum, hiss or a random popcorn/crackle?
Sent from my Apple ][e
On 31/01/2012, at 11:38 PM, "bigpeeet@rocketmail.com" <bigpeeet@rocketmail.com> wrote:
> Thanks
Re: Noise in my soup
2012-02-01 by bigpeeet@rocketmail.com
It's a high end hiss, like you'd expect from a channel strip gain being too high on a mixer. Seems like a bad signal/noise ratio in the output, if you know what I mean.
--- In PolySix@yahoogroups.com, Mike <mrjdevries@...> wrote:
> What type of noise?
> > Thanks
Re: [PolySix] Re: Noise in my soup
2012-02-01 by Dennis Matana
Sounds to me like an opamp isn´t functioning correctly. They tend to create a lot of noise if going bad.
http://soundcloud.com/wifi
www.facebook.com/matanateknik
From: "bigpeeet@rocketmail.com" <bigpeeet@rocketmail.com>
To: PolySix@yahoogroups.com
Sent: Wednesday, February 1, 2012 5:03 AM
Subject: [PolySix] Re: Noise in my soup
> What type of noise?
> > Thanks
2012-02-02 by Mike
You need to know where the noise is coming from.
Do not work on P6 while powered on!
Remove IC 10 on the voice board. This will take out all voices. Noise still there? If noise is gone, then we know it's not the FX section and last attenuator VCA.
If above removed noise, then...
Remove each SSM2044 one at a time checking which voice is responsible for the noise. Only do one SSM at a time, and don't mix them up.
Report back.
Mike
On 01/02/2012, at 3:03 PM, "bigpeeet@rocketmail.com" <bigpeeet@rocketmail.com> wrote:
> > What type of noise?
> > > Thanks
