Index last updated: 2026-04-28 23:40 UTC
Newbie question - Can't turn off modulation completely
2011-11-11 by marcomir27
Hello all !
I'm the proud owner of a refurbished Polysix that was brought back to life after dying from battery acid.
Here's my problem : even with the "MG Level" pot at 0, it is impossible to turn off modulation completely. Modulation can be increased or reduced (although, never completely) using the level pot and the mod wheel functions normally. I've tried several times using different patches or in manual mode, but I'm always getting the same result.
Another odd glitch (that may or may not be related to the mod problem) : speed/intensity pot  affects VCF cutoff when the effect switch is set at off.
Can any of this be fixed using the MG adjustment procedure ? Any idea ?
Many thanks !
-Nicolas (AKA Paraphonique)
Re: Newbie question - Can't turn off modulation completely
2011-11-13 by Daniel A
Was this a fixed original board or clone?
With the clone I had a similar issue and it was pointed out that I had inverted T3 or the SA798.
- Daniel
--- In PolySix@yahoogroups.com, "marcomir27" <lavn07@...> wrote:
> Hello all !
> Many thanks !
2011-11-13 by marcomir27
Ok, I've checked inside and I found a semi-loose connector near one edge of the clone board. After a quick check, it seems to be the cause of the problem. I'll do some additional tests later.
Cheers !
-N
> Regards,
> - Daniel
> --- In PolySix@yahoogroups.com, "marcomir27" <lavn07@> wrote:
> > Hello all !
> > Many thanks !
