> Unfortunately, both the calibration problem and MG bleedthrough are
> happening on the new clone board, not an old damaged board. It's not the
> first time I've seen new boards that wouldn't calibrate, either. Generally,
> the 4 and 8 lights come on and you can change the 8 to 7, 6, 5, but you
> can't make the 4 move down. I tried a couple of different types of DAC08 and
> even an original spec 1408 but it made no difference. I also tried a 4560 in
> place of the TL072.
> I did lift one end of R9 to verify that the MG leak was on this trace from
> CN06-2 to R9. The only way I can see this happening on a new board is if
> there is contamination on the bottom of CN06 between pins 1 and 2 that needs
> to be cleaned up, since the old Molex connector was moved from the old to
> new board and the area around CN06 is a real mess on the old board. I know
> it's a pain to remove these headers, but for a new board it makes more sense
> than cutting the trace.
> I think all Mike's flattery was an attempt to bribe me into not mentioning
> the other problems found on his new board. Ha, I warned you. This is for
> "educational purposes" for the rest of us trying to build new boards.
> 1) Blown fuses - solder bridge between C6 and C7. Although these two
> capacitors each have one pin connected to ground, the pins closest together
> are not ground, they are +15v and -15v. It might seem like a bad design to
> have these two pins so extremely close together but I guess it's the best
> way to get +15/-15 rails down to all the op-amps and comparators.
> 2) D4-D7 unstable, no control from sub octave switch - No solder on
> ground pin of IC29.
> 3) No MG at all, no Effects Speed control - Several pins not soldered
> on IC16.
> 4) From Tape not working - C4 had a 47nF (47000pF) cap in it instead
> of 470pF.
> Missing some IC socket pins while soldering is an easy thing to do with all
> those shiny pins on a shiny new board and is not as easy to find as you
> might think. I didn't notice these until I got it under a big lighted
> magnifier.
> Don B.
> _____
> From: PolySix@yahoogroups.com [mailto:PolySix@yahoogroups.com] On Behalf Of
> klosmon
> Sent: Thursday, October 13, 2011 2:47 PM
> To: PolySix@yahoogroups.com
> Subject: Re: [PolySix] Don Backshall is a great guy!!
> Nice guy, indeed.
> Two things:
> first, I've encountered many old 367 boards that were incapable of D/A
> calibration (as specified in the service documents) that still worked
> fine -- this is probably not an issue.
> Second -- regarding the MG bleedthrough...
> I've encountered this on many battery-damaged boards; it has to do with
> damaged traces bleeding through to each other.
> A fix I've found that works 99% of the time: cut the trace on the
> bottom of the board at CN06-2, and also the trace that goes to R9 (near
> CN05). Cutting the trace at both ends eliminates any possibility of the
> mod signal being affected by adjacent traces. The mod bleedthrough
> should disappear. Now solder a jumper between CN06-2 and the end of R9,
> and hopefully the mod function will work, without distortion or other
> problems.
> ~GMM
> Mike wrote:
> > Don Backshall solved all of my PolySix issues and did it for basically
> > a handshake. Furthermore, he mailed my KLM-367 board back to me in
> > good faith before my PayPal payment even cleared!!! I sent him as much
> > extra money as I could because he really deserved it. Here's the
> > correspondence bleow:
> > If the e-mail below can't restore your faith in blind internet
> > transactions, I don't know what will.
> > (Don's Response October 6)
> > Okay, the boards are on their way back. Priority Mail with delivery
> > conf # 03103490000077720492.
> > Still three problems that I am aware of:
> > 1) D/A calibration - Can't get the right lights to come on, but seems
> > to be in spec anyway.
> > 2) MG leak - I'm assuming this is caused by some crud between pin 1
> > and 2 on the bottom of CN06 header. I know these are a pain to remove,
> > but I think it needs to be done. Sounds really bad when it's cold.
> > Gets a little better when it warms up.
> > 3) MG delay - Known problem with 2N3904 in Q5 position. Using the
> > (2SC945) transistor from the old board seems to fix this, but the pins
> > are different. You can compare what's connected to what between old
> > and new boards to see what pin goes where. One of my old boards had a
> > 2SC2785.
> > $8.60 postage
> > $1.60 fuses
> > $0.15 capacitor
> > $10.35 grand total - You can send it to this Paypal acct
> > backshall1@... <mailto:backshall1%40bellsouth.net>
> > I'm pretty sure you can get this board sounding just like it should,
> > even if you can't get the right calibration lights to come on.
> > Have fun,
> > Don Backshall
> > _______________________________
> > (my response to him solving my problems October 05)
> > That's great!! It looks like I'm a decimal doofus! Ha Ha. What's the
> > bill? I can send you a PayPal payment today or tomorrow. I'll praise
> > your expertise on the Korg PolySix forum too if you're intersted.
> > Thanks again,
> > -Mike
