Index last updated: 2026-04-03 01:39 UTC
Polysix Programmer bug after preset playing into tape input
2011-08-23 by Kroutshev
 First thing, thanks a lot for that mailing list for polysix which is very helpfull. Second thing, i'm not english native speaker, by advance sorry for my bad english.
I contact you because as many people who are here, i have fixed a polysix with batterry leakage. I have replaced two 74LS08 completly eaten by acid and put wires to replace missing tracks. After that i have turn it on and the synth is working well. All sound functions are ok now. Happy man, i decide to test programmer but of course no sound inside. when i depress banks and programm key, i can access them but no sound.
I have downloaded wav file of stock presets on internet, i play them from my computer into tape input without checking volume. And since that sadly operation  when i try to access preset, i can't.
 When i depress bank A and programm 1 key, polysix produces a strange sound and program 2 led is on, i push programm 2 key and led of programm 1 is on. Same thing for the others programm keys. And i can't access to bank B C and D. i have the same strange sound when i push them.
If i enter into write mode i can access to all banks, 1 to 4 but immediatly i depress program key, write led stop to flash but nothing is written into memory.
Do you have an idea where i have to diagnose, of course i have checked tracks into klm367a board.
Thanks for your help.
Bruno
Re: Polysix Programmer bug after preset playing into tape input
2011-08-23 by Donald Backshall
Hi Bruno,
If the wrong LEDs light up, then there is most likely still a problem with the D0-D7 tracks on the KLM-367 board that go to connector CN10 and then to the display board. These all come from the two 74LS08 chips. Turn the Polysix off and use an ohm-meter to check connections from the 74LS08 chips to CN10, and also P10-P13 and P26,27 signals from CPU to CN10.
You didn't say if you put in a new battery and removed C49 and replaced R91 with a diode. These steps are necessary to save a program. When you are doing a write, pressing a program button should stop the LED flashing, so it seems that is working okay. You may have a bad memory chip, but you should probably check all tracks on the KLM-367 again. Check resistance on D0-D7 from CN10 to all points on the board that should have this signal. I am guessing you have the schematic diagrams since you have done much work already.
Also, some of these tracks go under the CPU. As Andy has told me many times, it is always best to remove the CPU, remove the CPU socket, clean underneath, and put in a new socket for the CPU. This has fixed some very strange problems for me.
Don B.
--- In PolySix@yahoogroups.com, "Kroutshev" <kroutshev@...> wrote:
> Hi,
> Bruno
RE: [PolySix] Re: Polysix Programmer bug after preset playing into tape input
2011-08-24 by Bruno BzH
Hi Don, thanks for you quick answer.Yes i have removed old battery to replace it by support and new coin cell and of course i have removed c49 and replaced R91.About cpu socket, i have already read what you say and tried to removed support cpu but without success. I have desoldered every pins but support seems to be stick on pcb.I will check again connections to be sure.About memory do you think that chips can have bad data inside after my wav file loading from tape input ? is it possible to done a hard reset on the polysix ?
Bruno
To: PolySix@yahoogroups.com
Date: Tue, 23 Aug 2011 23:48:50 +0000
Subject: [PolySix] Re: Polysix Programmer bug after preset playing into tape input
Hi Bruno,
Don B.
> Hi,
> Bruno
2011-10-04 by kroutshev
Hi P6 folks,
 i have found the solution, CMOS Ram IC32 was out of order. I have replaced it by a new one and my P6 is working well now.
Thanks for your help !
Bruno
> Bruno
> From: backshall1@...
> Hi Bruno,
> Don B.
> --- In PolySix@yahoogroups.com, "Kroutshev" <kroutshev@> wrote:
> > Hi,
> > Bruno
