Index last updated: 2026-03-31 18:47 UTC
Blue LEDs
Blue LEDs
2010-10-08 by silvercreekvalley
As part of my polysix 'refit' I'd like to replace
the red led's with blue ones. Is this likely to be
a problem - I'm assuming the red leds are fairly
standard size and voltage?
The switches seem to have a built in led, and I wonder
if its possible to replace those at all?
Anybody given this a try?
Ian
Re: [PolySix] Blue LEDs
2010-10-08 by Andrew Jury
Hi Ian,
It most certainly is and this is something I have had to do on a few
occasions. The series feed resistor also needs changing depending on the
spec of the LED. Use ohms law to figure that one out! I¹ll write you you
shortly ;-)
Cheers,
Andy
On 08/10/2010 16:46, "silvercreekvalley" <silvercreekvalley@yahoo.com>
> Ian
Re: Blue LEDs
2010-10-08 by ML
... and it may be a good idea to buy the LEDs and throw them on a breadboard first. This way you can experiment and find the right resistor value. Their brightness relative to the originals will vary for sure so once you know the voltage that Andy is talking about, base it on that and find the resistance that suits your taste. On paper it may be one value but it may prove too dull or bright so it's best to see the min action before committing.
Re: [PolySix] Re: Blue LEDs
2010-10-09 by Andrew Jury
Quite so! Blue is a much higher frequency than red in the colour spectrum
and some of these devices can be quite aggressive on the eye, so always best
to experiment first!
