Index last updated: 2026-03-31 01:44 UTC
Hardware screw sizes for the Polysix
2010-09-03 by ML
Has anyone got a list of the correct screw sizes for the P6? I've got one here that's missing almost all of the hardware and haven't got anything specific to go on. Thanks!
Re: [PolySix] Hardware screw sizes for the Polysix
2010-09-03 by Andrew Jury
Can you tell me which screws you have missing or even some photos of where
the holes are wouldn¹t go a miss! I have two complete P6 here in bits and I
can easily measure and tell you what heads/thread types they have!
Cheers,
Andy
> go on. Thanks!
Re: Hardware screw sizes for the Polysix
2010-09-03 by ML
That would be amazing. I'd greatly appreciate it. It's a pile of them!
- The four top panel outer screws
- The top panel 'inner' screws that fasten the PCBs
- The underside top panel screws that fasten those same PCBs to the brackets
- The bottom screws for the keyboard assembly
- The two screws underneath for the bend wheels
Heh - this poly is just a pile right now. Not quite in a bag but close :) The lower assembly PCBs are all in place though so at least those wood screws appear to all be there.
Re: [PolySix] Re: Hardware screw sizes for the Polysix
2010-09-04 by Andrew Jury
Nothing like a good project, eh?!
Here are the gory details for future posterity...
1. The four top panel outer screws: M3x14 black, pan cross head machine
screw with nylon washer.
2. The top panel 'inner' screws that fasten the PCBs: M2x5 black, pan cross
head machine screw with nylon washer
3. The underside top panel screws that fasten those same PCBs to the
brackets: M2x5 zinc cross head machine screw
4. The bottom screws for the keyboard assembly: M5x20 black, flanged pan
5. The two screws underneath for the bend wheels: M3x50 black, pan cross
OE&E. All measurements courtesy of my wonky steel rule. UOM metric because I
am a European sort of guy...
Cheers,
Andy
2010-09-04 by ML
Aaaahhh! Wooonderful. Huge thanks. This will be here for posterity!
It's amazing how getting the right hardware for synths is actually a real pain (or maybe it's just me). And yes - this will be a project! I've gone through a few synth projects where their condition is just absolutely horrible. This is one of them for sure. I'll snap a pic of the KLM board too. The traces are truly brutal.
I know what you mean! I like to have all the Œright¹ bits fitted in mine and
matching them can be a bit of an ordeal. The most difficult ones to find are
the long wood screw types that hold the boards in. They are always missing!
I just wish people would take more care. I have a E-mu Drumulator sitting
here on the bench that looks like it has been at the bottom of the sea for a
few years. What do people do with these things? I know what musicians can be
like, but come on!
Cheers,
Andy
> truly brutal.
RE: [PolySix] Re: Hardware screw sizes for the Polysix
2010-09-04 by backshall1 (dsl)
Hi Andy,
You seem to be off by one mm on some of the diameters. I haven't seen any M2
anywhere on the Polysix. All of the smaller ones are M3. Here are the ones
on the exterior:
M5x20 - (6) Keyboard
M4x14 - (4) Top panel - 2 on each end
M4x20 - (4) Across the bottom back of the panel
M4x50 - (2) Pitch bend assembly
M3x5 - (10) Top panel - hold the circuit boards with knobs up
M3x5 - (3) jack panel
M3x8 - (4) Power supply board - around the big Korg logo
M3x5 - (4) Around the AC inlet
M3x5 - (2) Holding the serial number plate. These are coarse thread screws,
not machine screws.
There are also two big ground lug bolts. I don't have any of those out at
the moment so I don't know if they are M4 or M5. Any bolt will do as long as
you have a nut for it.
They are measured out to the extreme edges of the thread, not just the
center bore. These are all black-oxide metric machine screws (bolts). I
don't have the thread pitch here at the moment, but I can find it somewhere.
They are all standard pitches.
The M5 for the keyboard seem to be the only ones that have a "Standard"
(American) size close enough to use. M5x20 can use 10-32x.75 which just
happens to be the standard rack-mount bolts which you can find anywhere.
M3 is common for the four bolts holding a CD/DVD drive in a computer, and
for many remote-control vehicles, although the R/C hobby shops seem to have
mostly hex-head, not phillips head, so you would need a 2mm hex key instead
of a screwdriver.
Don B.
_____
From: PolySix@yahoogroups.com [mailto:PolySix@yahoogroups.com] On Behalf Of
Andrew Jury
Sent: Saturday, September 04, 2010 6:02 AM
To: PolySix@yahoogroups.com
Subject: Re: [PolySix] Re: Hardware screw sizes for the Polysix
Cheers,
Andy
brackets
The
