Index last updated: 2026-04-03 18:16 UTC
(new) KLM 367 Calibration issue
2010-08-20 by Daniel A
Hello all just seeing if anyone can help me with an issue.
I have completed one of my new group buy KLM-367. Now it is installed and I am attempting to calibrate the board. I have completed both the power supply calibration and Step (1) resetting. Now with step (2) the D/A adjustment I am running into a problem. I set SW1 to test then toggle the Tape SW and LEDs 1 and 5 turn on. rotating VR7 or VR6 does not change the state of the LEDs.
Any clues?
Also has anyone run across a mod in their polysix where on the 369 the trace between D1 and J2 has been cut and then a jumper wire was installed to another location? I have a loose jumper wire coming from D1 for the time being I have soldered to J2 until I figure out why and where it was rerouted to.
- Daniel
Re: [PolySix] (new) KLM 367 Calibration issue
2010-08-20 by Jed Jorgensen
Hmmm.
This is going to sound dumb, but have you tried setting the test switch the
other direction?
I recall the dip switches seemed 'backwards' to me...
> LEDs.
> Any clues?
> to.
> - Daniel
Re: (new) KLM 367 Calibration issue
Jed,
I did not want to continue bugging you at work ;)
With the switch in the original direction no change in state takes place (LEDS A and Manual stay the same when toggling the tape switch). When test switch is thrown the LEDS will shift from A and Manual to 1 and 5. either direction on VR6 or 7 in adjusting does not change the state.
- Daniel
--- In PolySix@yahoogroups.com, Jed Jorgensen <jed.jorgensen@...> wrote:
> Hmmm.
> other direction?
Re: [PolySix] Re: (new) KLM 367 Calibration issue
Yeah. I was being dumb.
On Fri, Aug 20, 2010 at 3:13 PM, Daniel A <apophis93@yahoo.com> wrote:
> Jed,
> - Daniel
> --- In PolySix@yahoogroups.com <PolySix%40yahoogroups.com>, Jed Jorgensen
> > Hmmm.
> the
> > other direction?
