Index last updated: 2026-04-03 18:16 UTC
polysix switches to UNISON when you press 'd' key
2010-07-01 by silvercreekvalley
I have a polysix which was working fine yesterday, but
today when I press the middle 'D' key, the polysix
automatically switches to 'unison' mode. Pressing 'D'
again gives a garbled output, but all other keys work
OK. The 'D' is the d in the 3rd octave from the left. The
'd' in the 4th octave also does the same. All other keys
are fine.
I also noticed that when I switch on the polysix, it defaults
to UNISON mode and also voice 1 is sounding. This is
true even if the keyboard is unplugged, so its not a faulty
keyboard.
Any ideas what this bizare behaviour might be. I dont have
a schematic so not able to check.
My polysix is fitted with a new KLM-377 board which has
been working perfectly, and otherwise appears to work
fine.
Ian.
Re: [PolySix] polysix switches to UNISON when you press 'd' key
2010-07-02 by Chromatest J. Pantsmaker
the schematics and service manual are in the files section for the
yahoo group.  Haven't heard of this problem personally though.
On Thu, Jul 1, 2010 at 6:50 AM, silvercreekvalley
> are fine.
> keyboard.
> fine.
> Ian.
> PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6Yahoo! Groups Links
.sig
-Chromatest J. Pantsmaker
http://www.chromatest.net
Re: polysix switches to UNISON when you press 'd' key
2010-07-02 by Scott
--- In PolySix@yahoogroups.com, silvercreekvalley <silvercreekvalley@...> wrote:
> are fine.
> keyboard.
> fine.
> Ian.
Check to see if there's a wire or flexcable in the direct vicinity of the mechanics of the D key..Pushing or rubbing a cbale might cause weird stuff
2010-07-03 by silvercreekvalley
Its definitely not the keyboard, if I unplug it, I get
the same behaviour.
Sometimes, it manifests itself as doubling up of voices
eg press a key and get 2 voices sounding - all good fun :)
Andy suggested that I spray the key assigner CPU with freeze
spray and it definitely helps - so it looks like that might
be the issue. Many thanks Andy for the tips by the way.
Ian
