Index last updated: 2026-04-03 18:16 UTC
TC5514 memory chip
TC5514 memory chip
2010-03-09 by longenough2002
Now that the photocoupler is working, I've noticed some parameters not being stored for a few patches. The affected patches are A5,6,7 and C6,7. A5 just seems to lose the cutoff value. The others lose MG values and a couple seem to lose just about everything. I can't see anything that would cause this other than a bad memory chip. So, the question is, where is a good source for the TC5514 chip and are there other compatible replacements? It looks like Vintage Synth has them.
Re: [PolySix] TC5514 memory chip
2010-03-09 by Jed Jorgensen
I purchased them here:
http://www.questcomp.com/QuestDetailsAll.aspx?pn=TC5514APL-3&pnid=200555&stock=Yes
<http://www.questcomp.com/QuestDetailsAll.aspx?pn=TC5514APL-3&pnid=200555&stock=Yes>Not
cheap, but slightly cheaper than Vintage Planet if you are buying a few.
j
On Tue, Mar 9, 2010 at 9:33 AM, longenough2002 <backshall1@bellsouth.net>wrote:
2010-03-09 by Andrew Jury
Just before you ditch the old SRAM chip make sure you have correctly set up
the d/a converter using the procedure detailed in the manual!!
Cheers,
Andy
> Synth has them.
RE: [PolySix] TC5514 memory chip
2010-03-10 by backshall1 (dsl)
The DAC was off a bit. Must have bumped it while messing with all the other
stuff. However, readjusting it changed the sound of all patches a bit but
didn't help fix the few patches that just won't save what I put in them. I
guess I'll still have to try the RAM chip. Quest has a US $25 minimum and
Vintage Planet has a 15 Euro minimum. Anybody know a good psychic who can
tell me what parts I'll need next week or next month?
Don
  _____
From: PolySix@yahoogroups.com [mailto:PolySix@yahoogroups.com] On Behalf Of
Andrew Jury
Sent: Tuesday, March 09, 2010 1:04 PM
To: PolySix@yahoogroups.com
Subject: Re: [PolySix] TC5514 memory chip
Cheers,
Andy
being
just
seem to
other
Vintage
> Synth has them.
2010-03-10 by Andrew Jury
Worth making sure you are getting the right analogue voltages back from the
decode... It is always worth bearing in mind that the Intersil HM6514 is a
valid replacement for the old Toshiba SRAM, however, it does have slightly
higher current consumption so be aware. If you are located in the US this
lot reckon they have them available!
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&pro
ductId=43238&catalogId=10001&freeText=6514&app.products.maxperpage=15&storeI
d=10001&search_type=jamecoall&ddkey=http:StoreCatalogDrillDownView
A
> Don
> _____
> From: PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com>
> [mailto:PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com> ] On Behalf
> Of
> Andrew Jury
> To: PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com>
> Cheers,
> Andy
> being
> just
> seem to
> other
> the
> Vintage
>> > Synth has them.
Re: TC5514 memory chip
2010-03-27 by Robert Weigel
 I have good stock and will always beat any price including shipping. (I only charge 2.00 to pack/ship a chip. Most use snooty much more expensive methods which often cost near what the item costs)  Have NOS chips in stock. -Bob (sounddoctorin.com/synthtec/parts/key.htm for ordering instructions)
RE: [PolySix] Re: TC5514 memory chip
2010-03-27 by backshall1 (dsl)
Should have thought of asking you first, Bob. Too late now, though. I
already ordered a half dozen from Quest.
Don B.
  _____
Robert Weigel
Sent: Friday, March 26, 2010 11:58 PM
Subject: [PolySix] Re: TC5514 memory chip
--- In PolySix@yahoogroups <mailto:PolySix%40yahoogroups.com> .com,
