p6 Heart attak- ALL LED ON-
2010-03-06 by pietro
Hallo to all polysix lovers! that' the question: My P6 was not saving sound anymore after I put factory sound in it. ...I mean something was saved but with a very close cut off , only a clik was saved on the bank... So I thougt ...bad battery...no the battery was still good from the last time I replaced it (1999) the voltage is ok , no leakeage, exept for the old one from ten years ago. ...Maybe I have to do the procedure to calibrate everything.....ok , I put 56K resistor on the psu board...I set the voltages but when I disconnected the resistor ....(probably I shorted the pins) ...nothing flikering led on the bank... ..trying to switch from manual to test (desperation start) --I have to say that the battery was not on---- and now--- dead.no sound ,only all les on . panic : I checked the klm 367 board but is ok...(before was working) I still have the old battery ,but the voltage is ok 4v probably uP or some logic port are dead (killed) I don't know what to do... sorry for my english , pietro [Non-text portions of this message have been removed]
