Knob/Switch Problems - Are they KLM367 Related?
2002-08-03 by htill
Hello All,
I recently acquired a PolySix suffering from the oft-spoken
KLM367 Battery Leak. When I removed the battery, I noticed that
there was no white powdery residue from corrosion, just kind of
a stain on the board. Needless to say, my programmer is fried
and needs to be repaired. However, there are a couple of other
problems with the synth and I am wondering if getting the
KLM367 repair will fix these malfunctions, or whether or not my
synth needs more extensive work. I have tried contacting Scott
Rider, who still has not replied, so I thought I would bring this
question to the list.
First off, the synth works pretty well. Most everything outside of
the programmer works - and I have certainly come to love the
sounds that I can coax from it.
However, their are a few functions that do not work.
1. The Octave Select Knob in the VCO only produces sounds in
two registers (I think, though am not sure - the 8' and 4'
registers) - the third position (16') sounds EXACTLY the same as
when the keyboard is in the 4' register.
2. The SubOsc will not produce any sound when switched to
1OCT or 2OCTs down.
3. The Modulation Generator can only be routed to the VCO,
switching it to the VCF or VCA has no effect.
4. The Attenuator Knob does not work in both positions of the
VCA's mode switch - it does not work at all.
I am wondering if these problems are a result of the KLM367
malfunction, or if they are separate (perhaps caused by further
corrosion). I want to know whether or not the whole unit needs to
be sent in for repair or just the KLM367. Then hopefully I can get
in touch with Scott Rider and see if he is available do the needed
repairs.
Thanks in advance for any help with my problems.
-Henry Till
1OCT or 2OCTs down.
repairs.
-Henry Till
