Index last updated: 2026-04-03 01:39 UTC
loud VCA problem
loud VCA problem
2008-12-21 by wasteking1
I finally got my klm-367 working again (it had been on the fritz ) and
got the polysix all working and programmed  but noticed that when i set
the three way modulation selector switch down to VCA  i suddenly heard
a noticeable amount of white noise behind the desired sound. this white
noise is also affected by the mod-rate knob so that when the knob set
to any rate the noise pulses in the background when NO notes are played
and is a bit annoying. the other 2 positions of that switch  vco and
vcf  are quiet...no problems there ,  just the vca setting. any ideas?
if i can clean that up its running at 100% after a year in the shop. (
perhaps  then time for that 'double your memory'  mod?)
Re: loud VCA problem
2008-12-21 by Andrew Jury
Just a couple of things of note. I had a problem with noise with the
MG in VCA mode. This was a sort of thumping sound and was caused by
processor port lines P24 being disconnected and the 4042 not clocking
through data in a sychronised manner. However, if the sound is real
white noise and a hisssssss then might I suggest you look at the
signal path running through KLM-368 in and around IC20/21. In order
to spot the parasitic oscillation you'll do well to find and use and
oscilloscope for this problem.
Good luck and festive fun to you.
Cheers,
Andy
and
set
heard
white
set
played
and
ideas?
shop. (
