No sound in manual mode and tape load doesn't work
2008-11-23 by rodm99_99
Index last updated: 2026-04-03 18:16 UTC
Hello, I'm new to this forum. My polysix has been sitting for years. Recently, I got ambitious and bought a lithium battery and holder to replace the old leaky battery on my KLM-367 board. I also had to replace IC31. After i replaced the battery, I noticed that I would have more than 1 bank illuminated. I took the KLM-367 out and repaired the bad traces. Once I did, now at least I can select 1 bank at a time. Now, I can't get the polysix to make a sound in manual mode. Also, I can't get my data tape to also load back into the polysix. I've double checked the traces. Any other ideas? Thanks, Rod
2008-11-24 by Chromatest J. Pantsmaker
Yeah, the traces are messed up. On Sun, Nov 23, 2008 at 3:16 PM, rodm99_99 <rodm99_99@yahoo.com> wrote: > Hello, > > I'm new to this forum. My polysix has been sitting for years. Recently, > I got ambitious and bought a lithium battery and holder to replace the > old leaky battery on my KLM-367 board. I also had to replace IC31. > After i replaced the battery, I noticed that I would have more than 1 > bank illuminated. I took the KLM-367 out and repaired the bad traces. > Once I did, now at least I can select 1 bank at a time. Now, I can't > get the polysix to make a sound in manual mode. Also, I can't get my > data tape to also load back into the polysix. I've double checked the > traces. Any other ideas? > > Thanks, > Rod > > > > > ------------------------------------ > > PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6Yahoo! Groups Links > > > > -- .sig -Chromatest J. Pantsmaker http://www.chromatest.net
2008-11-24 by Andrew Jury
Hi Rod, Welcome to the forum! As our esteemed collegues have pointed out you should re-visit the work carried out in and around IC31. Sometimes track disconnection is not visible so you will need to do a proper continuity test. Also check the print around the battery's old location as it is very susceptable to damage. Make sure the top surface of the PCB is free of spilled electrolyte and clean with IPA. If you still have no luck then read post 1934. I know it is a shameless plug, but help is on offer if you are at an impass! Cheers, Andy --- In PolySix@yahoogroups.com, "rodm99_99" <rodm99_99@...> wrote: > > Hello, > > I'm new to this forum. My polysix has been sitting for years. Recently, > I got ambitious and bought a lithium battery and holder to replace the
2008-11-24 by Oliver Fairhall
I completely agree with this. When I repaired mine, there were traces which looked as though they had plenty of copper to conduct, but apparently the metal had corroded enough that the conductivity was compromised. Very careful Ohmeter testing isolated the bad traces. I wouldn't recommend a continuity buzzer for this work. You will need to be very methodical in your approach. If you can, use a PCB copper overlay printout, and trace out the conductivity, node by node. Test multipoint-to-multipoint at each termination of each node, and if there is a break in conductivity, then work your way inwards from each termination, to isolate the compromised trace sections. This sounds very finicky and tedious, but it is really not too bad once you get going. I guess you would have already fixed more than 95% of the issues, doing something very similar to what I have described. However, with this sort of work, it is often the last 5% that requires the most effort. Good luck. -Oli
On Mon, 2008-11-24 at 08:58 +0000, Andrew Jury wrote: > Hi Rod, > > Welcome to the forum! As our esteemed collegues have pointed out you > should re-visit the work carried out in and around IC31. Sometimes > track disconnection is not visible so you will need to do a proper > continuity test. Also check the print around the battery's old location > as it is very susceptable to damage. Make sure the top surface of the > PCB is free of spilled electrolyte and clean with IPA. If you still > have no luck then read post 1934. I know it is a shameless plug, but > help is on offer if you are at an impass! > > Cheers, > Andy > > --- In PolySix@yahoogroups.com, "rodm99_99" <rodm99_99@...> wrote: > > > > Hello, > > > > I'm new to this forum. My polysix has been sitting for years. > Recently, > > I got ambitious and bought a lithium battery and holder to replace > the > > old leaky battery on my KLM-367 board. I also had to replace IC31. > > After i replaced the battery, I noticed that I would have more than 1 > > bank illuminated. I took the KLM-367 out and repaired the bad traces. > > Once I did, now at least I can select 1 bank at a time. Now, I can't > > get the polysix to make a sound in manual mode. Also, I can't get my > > data tape to also load back into the polysix. I've double checked the > > traces. Any other ideas? > > > > Thanks, > > Rod > > > > > > ------------------------------------ > > PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6Yahoo! Groups Links > > >
