Index last updated: 2026-04-03 22:22 UTC
Help needed with KLM368 effects board
2008-11-17 by Dr Funk
I think I've finally brought my P6 back from the grave after a big
KLM367 rewiring job, and it's sounding great!  I've followed the
calibration procedure, and it now seems to be 100% functional, except
for a complete lack of effects.  Chorus/phaser have no effect at all,
and when I select Ensemble I just hear a loud repeating thumping noise.
I've checked CN03 from the KLM367, and pins 4, 5 and 6 measure 4.8V
when the appropriate effect is selected, while CN03-7
(speed/intensity) swings from -4.8V to +4.8V, depending on the front
panel pot.  Other parts of the KLM368 (headphone & output amps) appear
to be fine.
Any help would be appreciated!
Cheers
Frank
Re: Help needed with KLM368 effects board
2008-11-17 by Andrew Jury
Hi Frank,
I would venture that you may have not completed your mission with the
KLM-367. I would go back and check the tracks and function of the
logic at IC29 and IC34. Pay special attention to the control lines
P24 and P24. The track from the CPU port to this pin runs directly
along the area where the battery leaks! These two chips are 4042 quad
CMOS latches, so testing them might require the use of a logic probe.
Once you have verified this is working OK, then we can move onto the
effects processor board, but not until!
Let us know how you get on and if you need any further help!
Cheers,
Andy
except
all,
noise.
appear
> to be fine.
> Cheers
> Frank
Hi Andy
Thanks for your help!
I checked control lines P24 and P25 from CPU pins 35 and 36 to pin 5
of IC29 and IC35 (is this what you were referring to?), and there were
a few ohms of resistance, so I jumpered them.  No improvement though...
Unfortunately I don't have a logic probe - just a scope and DVM here...
I think I need further help already! :-)  Can this be diagnosed
without a logic probe?
Cheers
Frank
Hi Frank,
No problem, we are always here to help, if we can! Actually, I do
mean what I say. Look at the circuit diagram and carefully study IC29
and IC34. You will see that pin 5 is connected to the ports on the
CPU. It doesn't look like it on initial inspection, but it is true.
Without these present no data for the effects panel will be clocked
through.
What I would suggest is that you print out the KLM-367 circuit
diagram, take out a coloured marker and check the continuity around
both these ICs. As you do mark the line as checked in hideous yellow
ink. Apologies if this is 'grandmother' and 'eggs'!
You can check the logic levels with the oscilloscpe. Sorry I didn't
realize you had one! You could use the DVM to do this but you
wouldn't be able to see a pulse train (rapid changing levels) using
one.
Also you might want to fully test the continutiy of tracks D02 and
P11, P12, P13. These actually leave the 367 and are wired to the
switch via diodes. Sorry, it is labourious work, but one you spot the
fault it is a joy to behold!
Question? Does the EG Mode and Sub Osc switch do anything?
Let us know your progress.
Cheers,
Andy
Hi Andy
Much appreciated!
Actually, I do
> through.
These both appear to be fine.
No problem!  I am an 'enthusiastic amateur' when it comes to
electronics, but I've learned a lot in the past few months!  It's very
satisfying to begin to understand how my synths work.  Anyway, I've
checked continuity as much as I can, and everything seems to check
out.  I've checked IC29 and IC34 to the CPU and external connectors,
and it all seems to be ok.
> one.
Sounds good, but I'm not sure where to probe!  IC29 and IC34?
> switch via diodes.
These seem to be ok too.
I can't wait! :-)
Yes, both seem to be working properly.  Also, if effect intensity is
turned up full, when chorus is selected the filter seems to open up
slightly, and if phaser is selected there's a low level repeating
pulse sound audible.
Cheers
Frank
2008-11-18 by radek_tymecki
Try to check 4xxx circuits on effects board... also very popular
problem in korgs is that lm13600 got broken often. ne5517n is cheap
and good replacement for those!  :)
> Hi Andy
> Much appreciated!
> Actually, I do
> > through.
> > one.
> > switch via diodes.
> I can't wait! :-)
> Cheers
> Frank
Re: Help needed with KLM368 effects board - solved!!
2008-12-21 by Dr Funk
At long last, my P6 is alive!  Thanks to some help from Andy, for
which I am extremely grateful, the effect problem was traced to IC7
and IC8, the NE570N companders.  One of them had gone bad, so I
replaced both and the effects are working!
Cheers
Frank
2008-12-21 by Andrew Jury
Another one for the field notebook! Perhaps we should write a repair
manual for the P6...
Merry Xmas Everyone
Andy
> Cheers
> Frank
