Index last updated: 2026-04-03 22:22 UTC
Polysix repair - doesn't sound as it should
2008-09-17 by choco
Hi!
After digging within the messages I haven't found any similar
situation, so I decided to post.
I bought a year ago and old polysix and it sounded fine to me (maybe
lower than expected, I use it with an old guitar tube amp and I have
to select the high output with master at 12 o'clock to get it at
almost the same level as the guitar is)
A mounth ago I noticed that I had lost all my patches (although it was
sounding great and every pot worked fine). I did know about the
battery issues, but it hadn't worried me until that moment. I opened
the polysix and noticed that the battery mounting clamps were broken
and the batery was not feeding the klm367A anymore.
Well, it had leaked a little bit, but the circuit was almost perfect
and there were no signs of corrosion elsewhere. I cleaned all the
board with alcohol and care, replaced the battery and the 74LS08N
which is next to it just for security and then I made a mistake.
I broke a trace and shorted accidentaly 5V and ground.
After testing and noticing what the matter was, I removed that mistake
and everything seemed to work fine (the leds and so on), but when I
pluged the P6 to an amp (to the earphones too), I noticed that it
sounded weak and something like distorted. almost every pot didn't
affect as expected.
Do you have any idea of what can happen to my beloved P6?Any measure
that I could take from it to get deeper into? Unfortunately I don't
have an osciloscope to take accurate measures...
I also had a problem with 15Volt line, all the LEDs were ON when
starting up the P6, but never went OFF. In addition to it, the
Modulation LFO LED started blinking every time faster and faster until
it seemed to be just static ON. I solved it regulating the 15V pot to
get over 15.05 on my meter.
I will continue testing it, but it seems that I have reached my best
effort in front of it, and here in Spain it's almost impossible
finding a qualified vintage synth tech.
Thank you in advance.
Re: [PolySix] Polysix repair - doesn't sound as it should
2008-09-17 by klosmon
Hello-
Having repaired many of these, I would suggest that the most likely
cause is damaged traces due to the battery leak.
Even if the board looks good, the traces around IC31 (which you
replaced) are VERY delicate, and carry data lines that, if damaged,
effect all of the functions of the synth.
If you have any experience with electronics, get hold of the schematic
and use a continuity tester to test all traces from that IC;  if you
have a scope, that's even faster.
If not, you can send me the CPU board & I can look it over for you.
~GMM
analogsynthervice.com
choco wrote:
> Hi!
> affect as expected.
Re: Polysix repair - doesn't sound as it should
2008-09-18 by choco
Hi-
Thank you for your fast and kind reply.
I have visited your website several times when doing research for my
P6 and I had you in mind as an option if I couldn't work it out. My
synth comes from the states and I was bothered about sending it back,
but I've never thought before about sending just the board. It's a
great option.
I'll check one more time that traces and maybe I will re-solder them
and the socket more accurately just for testing.
Probably I will contact you in a week if I can't arrange to repair it.
And maybe I'll think about getting a scope.
Thank you!
--- In PolySix@yahoogroups.com, klosmon <klosmon@...> wrote:
> Hello-
> ~GMM
> choco wrote:
> > Hi!
> > affect as expected.
2008-09-20 by choco
Hi!
Finnaly I managed to repair it! It was just a track that I cut
accedentally and was under a printed number on the board (it was
almost impossible to see it)
Now I've got another problem. The synth sounds ok, it stores the
presets and so on, but it seems to be a problem with the modulation
section that it doesn't had before I managed to change the battery.
What happens is: when i switch the P6 on the LFO led starts flashing
faster and faster and every change of the pots doesn't affect to it.
Did you encounter this problem before? I've tried to do the Modulation
adjustment but the VR changes doesn't seem to affect to the signal
that is delivered to CN03-5. Well, I'm doing it with a digital
voltimeter which stands to measure Hz, but maybe that's not a good way...
any idea?
--- In PolySix@yahoogroups.com, "choco" <ignaciojimenez@...> wrote:
> Hi-
> great option.
> Thank you!
> --- In PolySix@yahoogroups.com, klosmon <klosmon@> wrote:
> > Hello-
schematic
> > ~GMM
> > choco wrote:
> > > Hi!
it was
mistake
> > > affect as expected.
until
pot to
Re: [PolySix] Re: Polysix repair - doesn't sound as it should
2008-09-20 by klosmon
Most likely cause is another bad trace.
Check all the traces to CN06 (D00 - D03;  P10 - P13).
Also keep in mind that these signals each have to connect to several
points on the board (for example, D00 connects to IC31-6, IC26-4,
CN06-3, IC28-4, IC34-4, etc etc).
~G
choco wrote:
> Hi!
> any idea?
> --- In PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com>,
> > Hi-
> > great option.
> > Thank you!
> > > Hello-
> schematic
> > > ~GMM
> > > choco wrote:
> > > > Hi!
> it was
> mistake
> > > > affect as expected.
> until
> pot to
2008-09-21 by choco
Hi.
I've checked tha traces and seemed to be ok, but accidentaly I found
something that I didn't understand.
The D00 (CN06-3) seems to be connected to the +3.6 pin of the battery
(and to the new diode which replaced the resistor there), and also to
the D15 anode (which is really close to that trace). I removed the new
diode and soldered it to the battery old soldering point which was not
used and goes through the other side of the board. I cut the trace
which connected the battery to the old resistor just for checking, but
the connection was still there.
Does it make any sense to you? The tracks and the board seem to be in
good condition and the battery didn't almost leak when I replaced it,
but it sounds to me that the board could be conductive or something
like that.
I just wanted to ask you before cutting all the traces on the board...
Maybe tomorrow I will try to remove all the D00 traces and make cable
connections.
Thank you!
> ~G
> choco wrote:
> > Hi!
way...
> > any idea?
> > "choco" <ignaciojimenez@> wrote:
> > > Hi-
back,
> > > great option.
repair it.
> > > Thank you!
> > > > Hello-
likely
damaged,
> > schematic
if you
you.
> > > > ~GMM
> > > > choco wrote:
> > > > > Hi!
me (maybe
and I have
> > it was
I opened
were broken
perfect
all the
74LS08N
> > mistake
when I
that it
didn't
> > > > > affect as expected.
measure
I don't
> > until
> > pot to
my best
2008-09-21 by klosmon
Sounds like D00 is shorted;  start by cutting the traces to that line
around IC31 -- if the short goes away, you know where to look.  If not,
cut the D00 trace to each of the other ICs & connectors, one at a time,
checking the status of the short as you go.
~G
choco wrote:
> Hi.
> like that.
> connections.
> Thank you!
> > ~G
> > choco wrote:
> > > Hi!
> way...
> > > any idea?
> > > > Hi-
> back,
> > > > great option.
> repair it.
> > > > Thank you!
> <mailto:PolySix%40yahoogroups.com> <mailto:PolySix%40yahoogroups.com>,
> > > > > Hello-
> likely
> damaged,
> > > schematic
> if you
> you.
> > > > > ~GMM
> > > > > choco wrote:
> > > > > > Hi!
> me (maybe
> and I have
> > > it was
> I opened
> were broken
> perfect
> all the
> 74LS08N
> > > mistake
> when I
> that it
> didn't
> > > > > > affect as expected.
> measure
> I don't
> > > until
> > > pot to
> my best
2008-09-22 by choco
Hi!
After cutting almost every trace on the D00 bus i realised that that
wasn't the matter of that short I discovered before.
In fact I'm not sure about what's happening, but I will try to explain
it, maybe you will find it normal.
Does it make any sense to you? (with the battery placed in the holder)
There is connectivity between the positive side of the battery and the
output of an AND gate on IC31 (Pin 6),(giving a value as if it were an
inverse diode or something like that) when plugging the negative probe
on the battery side, but it gives no connectivity when changing the
probes??
When removing the battery no connectivity issues are shown beetween them.
It seems something normal related to the values that the latch
delivers when the battery is in place, but I have not the tools to
measure this kind of logical issues and also I am not skilled to do it.
Any Idea that could affect to the effect speed?
Thank you one more time... now it's time to rewire D00 :(
> ~G
> choco wrote:
> > Hi.
> > like that.
> > connections.
> > Thank you!
> > > ~G
> > > choco wrote:
> > > > Hi!
modulation
battery.
flashing
to it.
Modulation
> > way...
> > > > any idea?
> > > > > Hi-
research for my
out. My
> > back,
It's a
> > > > > great option.
re-solder them
> > repair it.
> > > > > Thank you!
> > > > > > Hello-
> > likely
(which you
> > damaged,
> > > > schematic
> > if you
> > you.
> > > > > > ~GMM
> > > > > > choco wrote:
> > > > > > > Hi!
similar
> > me (maybe
> > and I have
get it at
(although
> > > > it was
about the
> > I opened
> > were broken
> > perfect
> > all the
> > 74LS08N
mistake.
removed that
> > > > mistake
> > when I
> > that it
> > didn't
> > > > > > > affect as expected.
> > measure
> > I don't
ON when
it, the
and faster
> > > > until
the 15V
> > > > pot to
> > my best
impossible
2008-09-22 by klosmon
There shouldn't be any connectivity -- either there's a short you
haven't found yet, or there's a problem with IC 31.
I've about reached the limit of my long-distance diagnostic ability....
~G
choco wrote:
> Hi!
> probes??
> > ~G
> > choco wrote:
> > > Hi.
> > > like that.
> > > connections.
> > > Thank you!
> > > > ~G
> > > > choco wrote:
> > > > > Hi!
> modulation
> battery.
> flashing
> to it.
> Modulation
> > > way...
> > > > > any idea?
> > > > > > Hi-
> research for my
> out. My
> > > back,
> It's a
> > > > > > great option.
> re-solder them
> > > repair it.
> > > > > > Thank you!
> > > > > > > Hello-
> > > likely
> (which you
> > > damaged,
> > > > > schematic
> > > if you
> > > you.
> > > > > > > ~GMM
> > > > > > > choco wrote:
> > > > > > > > Hi!
> similar
> > > me (maybe
> > > and I have
> get it at
> (although
> > > > > it was
> about the
> > > I opened
> > > were broken
> > > perfect
> > > all the
> > > 74LS08N
> mistake.
> removed that
> > > > > mistake
> > > when I
> > > that it
> > > didn't
> > > > > > > > affect as expected.
> > > measure
> > > I don't
> ON when
> it, the
> and faster
> > > > > until
> the 15V
> > > > > pot to
> > > my best
> impossible
2008-09-23 by choco
Yesterday I managed to rewire D00 and replaced IC31 but nothing
changed, effect speed LFO continued accelerating itself and that
strange connectivity issues were present.
Just to shed some light. The connectivity issues could be just related
to my inexperience dealing with measurement equipment, because I use
the Diode-measure mode, which is expected to "bip" if there is a
short, and what I get a negative measure (-837)which undoubtedly bips
on mi multimeter. unfortunately I don't know what kind of measure it
is (Volts, milivolts, amperes...) If it can help, it is exactly the
same measure that I get when measuring D15, where the voltage drop is
exactly what the battery is delivering (3.02) and obviously I've
checked the diode and it is OK.
Thank you very much for all your help. I will spend some time checking
traces and, if I can't find what's wrong, I will get back to you to
send the board to your more skilled hands.
> ~G
> choco wrote:
> > Hi!
> > probes??
beetween them.
do it.
If not,
a time,
> > > ~G
> > > choco wrote:
> > > > Hi.
found
battery
also to
the new
was not
checking, but
to be in
replaced it,
something
> > > > like that.
board...
make cable
> > > > connections.
> > > > Thank you!
several
IC26-4,
> > > > > ~G
> > > > > choco wrote:
> > > > > > Hi!
(it was
stores the
> > modulation
> > battery.
> > flashing
> > to it.
> > Modulation
the signal
not a good
> > > > way...
> > > > > > any idea?
> > > > > > > Hi-
> > research for my
> > out. My
sending it
> > > > back,
> > It's a
> > > > > > > great option.
> > re-solder them
> > > > repair it.
> > > > > > > Thank you!
> > > > > > > > Hello-
the most
> > > > likely
> > (which you
> > > > damaged,
of the
> > > > > > schematic
that IC;
> > > > if you
over for
> > > > you.
> > > > > > > > ~GMM
> > > > > > > > choco wrote:
> > > > > > > > > Hi!
> > similar
fine to
> > > > me (maybe
tube amp
> > > > and I have
> > get it at
> > (although
> > > > > > it was
> > about the
moment.
> > > > I opened
> > > > were broken
was almost
> > > > perfect
cleaned
> > > > all the
and the
> > > > 74LS08N
> > mistake.
> > removed that
> > > > > > mistake
on), but
> > > > when I
noticed
> > > > that it
every pot
> > > > didn't
> > > > > > > > > affect as expected.
beloved P6?Any
> > > > measure
Unfortunately
> > > > I don't
> > ON when
> > it, the
> > and faster
> > > > > > until
> > the 15V
> > > > > > pot to
reached
> > > > my best
> > impossible
