> 3: Stupid question: People talk about replacing the R93 to a "1k2
> ohm" resistor -is this the same as a "1.2 k ohm"?
Yes, it's the universal standard. Some areas use 1.2 some use 1,2
etc.. so.. to make it easy, you put the modifier where the decimal
goes.
> 4: Will a 1/8W carbon resistor do?
I would guess so. I don't know how critical it is, but you might want
to look for a 1% resistor, or measure them until you find one that is
as close as possible to your desired value. I always use 1/4W carbons
because I buy them in bulk for $.01 each.
> goes.
