Index last updated: 2026-04-03 01:39 UTC
VCA Calibration looking bleak
2007-10-07 by sdlarch1
According to the calibration manual, the waveform at CN03-5 should look
like this:
  [Click for a larger image. Opens in a new window]
<http://01eea9c.netsolhost.com/poly6/cal_snipet_large.jpg>
Mine looks like this:
<http://01eea9c.netsolhost.com/poly6/cn03-5_read_large.jpg>
The controls are set like this:
<http://01eea9c.netsolhost.com/poly6/vca_adjust_presets_large.jpg>
Does anyone see something blatantly wrong? Any ideas? I've performed the
battery swap. I went throught the cal procedure after the battery
operation and this waveform looked fine. The only other mod I've done is
that PC1 was replaced with a VTL5C3 and R93 was changed to a 1k2 ohm.
-Sam
Re: VCA Calibration looking bleak
2007-10-10 by sdlarch1
I found the issue.  I reseated the IC that was replaced during the
battery procedure. (put it in a socket instead of directly on the
board)
look
> like this:
performed the
done is
ohm.
> -Sam
