problem with my P6 : strange filter modulations...
2007-06-05 by analog_audio01
Index last updated: 2026-03-31 14:03 UTC
2007-06-05 by Chromatest J. Pantsmaker
On 6/5/07, analog_audio01 <analog_audio01@yahoo.de> wrote:
> hello,
> I have a big problem with my polysix.
> everything is fine, but when I turn it on, after a minute or two the
> filter makes some strange modulations.. sounds a bit like fm ... I
> will post an audio file soon...
> I already changed the voice pcb from another polysix, and found out
> that there's a problem with the digital board (klm367).
> I already changed all electrolytic caps from the klm367, but no
> improvement. I replaced the battery some days ago, the original
> battery was only leaked a bit, but the pcb was clean and all traces on
> the pcb are looking good.
> do you have an idea what could be a reason for this problem...??
> thanks,
> mat
> PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6
.sig
-Chromatest J. Pantsmaker
http://www.chromatest.net
2007-06-05 by klosmon
>Yes, you have damaged traces. Check each one, one at a time. Use a[Non-text portions of this message have been removed]
>magnifying glass if you need to.
><<mailto:analog_audio01%40yahoo.de>analog_audio01@yahoo.de> wrote:
> > hello,
> > thanks,
> > mat
> <http://www.acc.umu.se/~amber/Poly6>http://www.acc.umu.se/~amber/Poly6
> > Yahoo! Groups Links
>.sig
><http://www.chromatest.net>http://www.chromatest.net
2007-06-06 by analog_audio01
2007-06-21 by analog_audio01
2007-06-22 by Chromatest J. Pantsmaker
On 6/21/07, analog_audio01 <analog_audio01@yahoo.de> wrote:
> ok, I checked the klm361 (digital pcb)
> all traces and thru-holes in the battery section are ok...
> I measured them with my multimeter.
> I made a sound example so that you can listen how bad my poly6 sounds:
> http://www.cmaudio.net/poly6prob.mp3
> as I wrote earlier in my thread the problem is on the klm 361 pcb (I
> interchanged it with the board from a working p6 and then it was fine...)
> I think the dc voltage from the digital board are not clean..
> I already changed all electrolytic caps, but what should I do next?
> change some ics?
> or borrow a scope and measure the pins at the connectors? looking for
> some voltages that could cause this modulations??
> thanks for your help
> mat
.sig
2007-06-22 by analog_audio01
>fine...)
> Did you check the continuity of the board connectors? I've seen
> corrosion inside the connectors. Just do a simple continuity check
> from the board on one side of the connector, to the other board on the
> other side of the connector... The traces might be fine, but if the
> voltages can't get to the traces, your sol.
> > change some ics?
> > mat
> > Yahoo! Groups Links
> .sig
2007-07-09 by analog_audio01
>sounds:
> thanks,
> I'll try that, but I think it's not a connector problem,
> when I switch the polysix on, everything is fine for a few minutes,
> then these strange modulations starts... like you can hear in the mp3
> mat
> --- In PolySix@yahoogroups.com, "Chromatest J. Pantsmaker"
> > >looking for
> fine...)
> > > change some ics?
> > > mat
> > > Yahoo! Groups Links
> > .sig
2007-07-09 by Chromatest J. Pantsmaker
On 7/9/07, analog_audio01 <analog_audio01@yahoo.de> wrote:
> I checked all the connectors, changed 2 ics near the battery and it
> became much better.
> when i turn on the unit the first 20-30 minutes everything works fine,
> but when the p6 has completely warmed up, everything sounds total wierd...
> are there any temperature sensitive parts that I should consider to
> change? maybe the power supply..??
> btw: when I don't close the lid, everything is ok.
> thanks for your help.
> mat
> --- In PolySix@yahoogroups.com, "analog_audio01" <analog_audio01@...>
> wrote:
> > thanks,
> > mat
> sounds:
> > fine...)
> > > > change some ics?
> looking for
> > > > mat
> > > > Yahoo! Groups Links
> > > .sig
.sig
2007-07-16 by Wayne and May Rudd
