Index last updated: 2026-04-03 01:39 UTC
Ok i am a moron...
Ok i am a moron...
2006-10-17 by bildfantomen
Please explain to me how the Opto thingamajig is supposed to be
connected, all it says in the Files section is what resistor to
change. It doesn't explain to a moron how the vtl5c3 is connected,
like I said before it has 4 connectors, and the old part has 5 (or 6,
i'm confused)
What connector goes where?
I don't know much about this but I know that I want the F***er to work
properly.
And I would like to apologize for my temper, and aska again, does any
one have any idea why my polysix arpeggiator slows down when i fiddle
with the adsr and EG settings???
There I said it, sorry but it appears I'm a moron...
Re: Ok i am a moron...
2006-10-17 by David Davis
I had this exact same dilemma last night -
but careful examination will show you that only 4 of the pins on the
old opto component is connected to anything.
I got my new opto from http://www.rswww.com
Look at part
http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?N=0&Ntk=I18NRSStockNumber&Ntt=2508981626&Nty=1&D=2508981626&callingPage=/order/OrderHistoryView.jsp&BV_SessionID=@@@@0781451492.1161086007@@@@&BV_EngineID=cccladdjdljgfkfcefeceefdffhdffo.0&cacheID=uknetscape&Nr=avl:uk
(RS Stock no. 2508981626, check out the Data Sheet document)
You'll see the new opto has a corner cut out to indicate where "pin 1"
is.
The old opto has a wee dot at the upper left to indicate its "pin1"
Korg's surviving PS6 schematics go horribly fuzzy at this point, but
if you shine a light through the board you'll see which pin trace
leads to R93 (pin 2, the +ve end of the LED), whilst pin1 goes to ground.
> i'm confused)
> properly.
